Question about Haier 3.6 cu. ft. / 102 liter Chest Freezer HCM036PB
Need a operators manual for haier chest freezer hcm036pb
    Problem Solver:
  • 3 Answers
Http://www.managemylife.com/mmh/owner_manuals/1018/HAIER-Chest-Freezer-L0501492
I found the manual at the above link. The Haier freezer models include:
HCM036PB
HCM045PB
HCM050PA
HCM073PA
Posted on Jul 17, 2012
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 124 Answers
SOURCE: freezer freezes but does ever stop running
thermostat is stuck on! set to medium setting and gently tap stat. does it turn off? it was stuck. does it still run? its still stuck. if you feel comfortable find stat and power in and out. disconnect - it has to turn off then. but 99 % of the time its the stat. they fail closed and run 24 -7 or fail open and temps get real hot and they never close and restart compressor . yours appears to have failed closed. sometimes you can firmly twist em max cold to min cold a few times and break the stuck contacts and they'll do ok for a while. try to reset at a little higher or warmer temp when done so its not making and breaking on the same old worn spot again. good luck.
Posted on Nov 21, 2008
peyton32034
peyton thompson
  • 410 Answers
SOURCE: Where can we get a manual for the HCM073PA Haier
on your model freezer one of the switches actually turns the unit off and on and the other turns the alarm off and on. unfortunatley i'm not sure which one does which. here is the part numer for the manual RF-9999-208 and it can be ordered thru sears.com for 3.50 alternatively you could check haier's web site to see if they have a downloadable version. thanks Peyton
Posted on Jul 04, 2009
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: Deep freeze compressor not kicking on.
Sounds like the relay contacts are staying open.
Posted on Jul 30, 2010
walterkunesk
Wally Bald Guy
  • 683 Answers
SOURCE: How much amps, volts and
all this is on label on equipment.
Posted on Feb 28, 2011
Lost owners manual
You only require fast freeze if you are using the freezer for the first time, after a defrost, or if you add a large quantity of fresh food to an already running freezer. Most freezers require about eight hours at fast freeze. As to the temperature setting I would suggest you purchase a purpose built freezer thermometer (very cheap) and place that on top of the food. With the thermostat control set mid way (about 3 or 4) check the thermometer occasionally see what the temperature reads. It should be around -18C, if it's lower then set the thermostat lower at 2-3, if its higher set the thermostat higher at 4-5. Repeat this until the freezer temperature is correct.
Dec 26, 2013 | Haier 3.6 cu. ft. / 102 liter Chest...
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
I need a replacement for the keys of my HAIER 7.3 FRREZER
what do the dial and buttons at the bottom to be set as.we dont have a manual?
Jan 12, 2013 | Haier 7.3 cu. ft. / 207 liter Chest...
Why can't a Haier chest freezer be put in garage?
The only problem that you might have is with the coils and the flux capacitor. If you clean the coils, it should be fine.
Dec 18, 2011 | Haier Freezers
Lost manual and need to defrost
This is likely a manual defrost freezer, which means you have to remove the food, unplug the unit, and let the ice melt on its own. Do not, and i repeat, DO NOT poke the ice away from the walls. I guarantee if you poke the ice away from the wall, you'll poke a hole in the wall, and force yourself to buy a new freezer.
SLOWER IS SAFER. put some boiling water, in the pot, inside the freezer, or use a hair dryer.
Sep 30, 2010 | Haier 4.5 cu. ft. / 127 liter Chest...
Any possibility you can help troubleshoot a larger upright freezer? Our freezer is 3 years old. It sounds like it is working -- I can feel cold air and hear it humming, but as of yesterday it stopped...
Assuming the thermostat is set to call for cooling (sometimes they get bumped), check the condenser coils, fan, etc for debris build up and clean as needed.
Is the freezer frost free? If so, it's possible the defrost timer is stuck in defrost. There should either be a mechanical timer or it could be electronic these days. Check for bad connections or any obvious signs of damage (burn marks)
Make sure the freezer door closes tightly
Jul 25, 2009 | Haier 3.6 cu. ft. / 102 liter Chest...
Where can we get a manual for the HCM073PA Haier chest freezer? Why are their two on/off switches on this model, one black and white and the other red and white?
Jul 04, 2009 | Haier 7.3 cu. ft. / 207 liter Chest...
Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Apr 30, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Haier 3.6 cu. ft. / 102 liter Chest Freezer HCM036PB Logo
631 people viewed this question
Top Haier Freezers Experts
Marvin
Marvin
Dennis Boxerman
Are you a Haier Freezer Expert? Answer questions, earn points and help others
