Question about LG WM-1832C Front Load Washer
Hello, I have the LG Washing Machine Model WM1832CW and I'm having drain issues. The machine itself wont drain the water out. The water remained in the machine. Please advised on what I need to do in order to fix this.
  • LG Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Apr 26, 2011
6ya staff
SOURCE:
How would I drain remaining water from washing machine?
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
Fix Washing Machine That Won Drain Washer Not Draining Water
Jan 26, 2016 | Washing Machines
Lg wahser wm1832cw flashes oe on readout. nothing in drain
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Aug 25, 2010 | LG WM-1832C Front Load Washer
Hello, i bought an LG front loader washing machine (WD 11020D)just 2 weeks back. After every 2-3 washes, the drain filter becomes full of water in a way that even water remains in the drum after the...
you may have a kinked drain hose so the water cannot drain out properly. or if you have the drain hose plumbed into your sink u bend the hole in the spigot may not be opened up large enough.
Aug 23, 2010 | LG Washing Machines
I neet o replace drain pump on a LG wm1832cw model
its not easy, but you'll have to lay the washer on its back and take off the crate like bottom panel. Discontect all the hoses. Disconnect the electrical line going to the pump. If you can, try and seperate the pump motor from the housing by unscrewing two screws on the housing, which will seperate the motor from the housing, If you cant get to it, I actually broke the screws on the drain filter housing to get it loose. I secured it back with the other front loading screw and some gorilla glue, shouldnt be a problem. I should at least get another 6 years out of this pump. Good luck.
May 31, 2010 | LG WM-1832C Front Load Washer
Noisy on spin cycle LG WM1832CW
this is joyce
Go to lg.com and download your manuel put in your model #
thanks
joyce
Feb 07, 2009 | LG WM-1832C Front Load Washer
LG WM1832CW water leaking
your valve is not closing or your cycle isn't reading correctly. there should have been a diagnostic read process that should have came with the machine. if not you may have to end up buying a new drian assembly
Jan 15, 2009 | LG WM-1832C Front Load Washer
I have LG WM1832CW washing machine. It is having problem now. The water comes out from the drain bump filter right away during the water filling cycle. I also tried just put the water into int drum without...
your drain hose is in the drain tube to far, pull out the hose and only put it in about four inches into the pipe. when you drain line is in to far the hose get a syhpon effect from your sewer.
LG WM1832CW Drain Pump
i drained it first with the pull out hose in the access panel on the bottom left. i tilted the washer back to remove it from the bottom.
Jun 17, 2008 | LG WM-1832C Front Load Washer
LG WM1832CW Front Load Washer
FE means water is overflowing. Check pump filter. Check water level switch and hose. Also check that drain hose isn't too low causing it to refill itself continuously. In any case the drain pump should run for 4 minutes to try and eliminate the extra fill
Dec 28, 2007 | LG WM-2277HW Front Load Washer
LG WM-1832C Front Load Washer Logo
443 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
