the error code for full waste toner is E019. To solve the problem, as you know, you need to clean/empty the waste toner box.
To do these:
On left side way of copier, in lower left angle, there is plastic cover with one screw. Unscrew and remove the plastic cover, then pull out to remove waste toner box. Empty it! With piece of clothe, clean the "neck" of the bottle, because on round inserts on neck, is where the sensor reads the FULL or OK state.
Put it back in and turn off and on the copier.
Hope that helps!
