Televison & Video Logo
Matthew Smith Posted on Apr 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i got this TV from my uncle he said it was making a "cheeping like" sound so i said i would take it, im a sophomore at a tech school and have good experience with electronics work (I'm studying IE industrial electronics at this school) what should i start with, Thanks.
Anonymous
Level 2:
  • Expert 119 Answers
  • Posted on Apr 26, 2011
Anonymous
Expert
Level 2:
Answers
119
Questions
0
Helped
45881
Points
470
Hello matter0464 and a warm welcome to Fixya. The issue you are asking about is actually rather common with the RCA P56812BL after it gets a few years on it. The problem is most likely the high voltage circuit located on the main board. I would start there before looking elsewhere. Also inspect the 195 AP fuse on the main board as well because it is known to blow out periodically. Well I hope this was helpful and good luck to you. Thanks for using FixYa.
  • Matthew Smith
    Matthew Smith Apr 26, 2011
    if this fuse is small then its the one i found its fine, not blown out
  • Anonymous Apr 27, 2011
    Hello again matter0464.I'm sure your aware this is going to be a trial and error process. The next thing I would check is the horizontal circuit. It also has been known to short out. A few other things that should get your attention may be the high voltage transformer, high voltage splitter as well as the horizontal output for a possible short. If all these check out ok try checking the B+ voltage on the collector. Let men know how it goes. I will check ino some service manuals to see if any other problems come to mind. Thank you for updating me on your situation and I hope I have helped to put you in the right direction.
How the negative effects of technology can be eliminated?
Sounds like something I had to read about recently in tech school; but it was just a jaded opinion someone threw online; and he found and quoted a few other people in respectable professions that share his view. I could post just as many counter-facts about anything now a days with online web searching. So why weigh truth based on what a somewhat collective opinion says. Just sounding good, doesn't make it good, does it? People can be compelling about anything and later find out they were completely wrong. It happens... I'm going to go with there isn't negative effects of tech if it isn't harming anyone. Besides it is too broad of a question to answer adequately because tech isn't in just 1 industry, but many. Focus on 1 specific tech and in the details is where improvements are made.
Requirements to study bookeeping
If it's basic then just basic hi school math...I had it in my sophomore year in hi school. As you progress you'll find out what further requirements would be.
How to improve sound volume
HI GO AND BIY A CHEEP SOUND BAR AND PLUG IT IN IF AN OLD TV BIY A POLARUED SOUND BAR AS YOU CAN PLUG IT INTO THE EARPHONE JACK
Hi i got this TV from my uncle he said it was making a "cheeping like" sound so i said i would take it, im a sophomore at a tech school and have good experience with electronics work (I'm...
This problems it is the tv convergence board it is dead.The tv convergence board is not distrubuting voltages around the tv anymore.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a tv convergence kit belong to ur tv model and repair it ur self.The tv convergence kit also came with a tutoring DVD disc.
1helpful
RESOLLUTION ISSUES OR GRAPHICS CARD UPGRADE?
Can you please put forth the problem in minimal words?
No power Up , No Sound , No picture
Im sorry tom have to inform you that a red light blinking is an indication that the main power supply is good BUT the sweep supply has a problem .. Most likly the high voltage transformer as well as the horizontal transistor is bad. if you have no solid state repair experience, you will not be able to fix this set on your own as we techs do gfo to school to learn the circuits in these sets and there are safety issues you have to know and equipment you have to have. sorry my freind but you going to need to call or take the set top a trained tech to trouble shoot as you cannot look at the board and see a problem. you have to troubleshoot the board and test the circuitry.
2helpful
I've got a pana inverter CS-E24FKR, and the timer icon is blinking. I have not set a timer and i can not get the unit to respond. I tried holding the "check" button down for 5 seconds, then...
I had the same problem with a Panasonic Inverter mini split model cs-e12eku and i had to turn it off using the main power breaker switch. ( I could never get the darn error code.) I left it off for a couple of minutes and it seems to reset. My uncle is in the ac business and he has heard from other ac techs that the Panasonic ac's are problematic, sounds like it might be true...I suspect that the time, my unit worked perfectly for from 11/06 to June 08 and living in the tropics I used it every day I havent called Panasonic but it sounds like a faulty circuit board.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
