Thats caused by a bad optical block. The cost of that repair will almost always be greater than replacing the TV.Thats a very common issue with alot of Sony DLP models which suffered that optical block issue with the blobs of color usually blue or green
Hi, I'm afraid, it is problem of optics unit block (light engine), there
are 3 LCDs red-green-blue for color picture formation and blue LCD
sounds bad, please call local TV tech for fix.
Thanks.
If its model number is KF-50WE610, had you replaced its Lamp recently? If Lamp is replaced, please check Lamp cover/ door that is not seated properly, make sure its fixed securely. 3 times light flashing shows Lamp cover error.
Green flashing is normal. Red flashes are error codes. Count the error flashes.
3x - Lamp cover position or cover detect switch bad.
4x - One or more fans failed RPM test
5x - Lamp power supply/ballast failure
6x - Thermal fuse failed (usually)
