Question about Grandstream GXP-2000 IP Phone
Call forward will not turn off, have tried *74 & *73 , have rebooted and turned off then on, call divert symbol still on and phone calls still diverted.
    Scholar:
  • 80 Answers
To set Unconditional Call Forward ON Dial "*72" for a dial tone. Dial the forwarding number followed by "#". Wait for dial tone. LCD will display "Call FWD Activated"
To Cancel Unconditional Call Forward: dial "*73" and get the dial tone, then hang up. LCD will display "Call FWD Activated
but, since you have tried those two, it could be that there might still be a different type of call forward option that is still ON, on your phone like Busy Call Forward and Delayed Call Forward 1. To Cancel Busy Call Forward: dial "*91". Wait for dial tone. Hang up.
2.To Cancel Delayed Call Forward: Dial "*93" for a dial tone, then hang up.
Let me provide you a link to the website which I used as a reference for your future reference.
http://www.grandstream.com/user_manuals/GXP_User_Manual.pdf
Posted on Apr 27, 2011
Testimonial: "Thank you!!! My boss is now happy he can annoy me again :) "
6ya staff
SOURCE:
How to divert an incoming call?
There are several methods. Phone company provided call forwarding instantly sends calls to a phone number you set on your main phone line, that you turn on with *72 + the destination # and turn off with *73. Or "Call Forwarding No Answer" that transfers the call after several rings to a pre-determined number, all setup by the phone company on your main line. Or, on the Panasonic systems (there are many), you do the same using several code choices, a bit more complicated. Your installer must set the system to allow the system to send calls to an outside line, and you must have more than one line because the destination number is dialed on a different line than the line that's receiving the call. Your Panasonic "Operating Manual" lists these codes and methods with instructions, you'll find them listed in the table of contents under "Call Forwarding" with step by step pictured instructions.
Apr 09, 2014 | Panasonic KX-T7730 Corded Phone
Tip
Phone Codes Nokia
Nokia
CODES DESCRIPTIONS
*3370# Activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR)
*#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
*#4720# Deactivate Half Rate Codec
*#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
*#9999# Phones software version if *#0000# does not work
*#06# For checking the International Mobile Equipment Identity (IMEI Number)
#pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
*#147# (vodafone) this lets you know who called you last
*#1471# Last call (Only vodofone)
*#21# Allows you to check the number that "All Calls" are diverted to
*#2640# Displays security code in use
*#30# Lets you see the private number
*#43# Allows you to check the "Call Waiting" status of your phone.
*#61# Allows you to check the number that "On No Reply" calls are diverted to
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to
*#67# Allows you to check the number that "On Busy Calls" are diverted to
*#67705646# Removes operator logo on 3310 & 3330
*#73# Reset phone timers and game scores
*#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible
*#7760# Manufactures code
*#7780# Restore factory settings
*#8110# Software version for the nokia 8110
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again
*#94870345123456789# Deactivate the PWM-Mem
**21*number# Turn on "All Calls" diverting to the phone number entered
**61*number# Turn on "No Reply" diverting to the phone number entered
**67*number# Turn on "On Busy" diverting to the phone number entered
12345 This is the default security code
press and hold # Lets you switch between lines
*#3283# or *#DATE# Date of Manufacture
*#682371158412125# Software Version
on Aug 30, 2009 | Nokia 9500 Communicator
Reset my memory card pasword
1. Code *3370# -Activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx 5%.
#3370# -Deactivate Enhanced Full Rate Codec (EFR).
.2. *#4720# -Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time.
*#4720# -Deactivate Half Rate Codec.
3. *#0000# -Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type.
4. *#9999# -Phones software version if *#0000# does not work.
5. *#06# -For checking the International Mobile Equipment Identity (IMEI Number)
6. #pw+1234567890+1# -Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
7. #pw+1234567890+2# -Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
8. #pw+1234567890+3# -Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
9. #pw+1234567890+4# -SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
10. *#147# -(vodafone) this lets you know who called you last.
11. *#1471# -Last call (Only vodofone).
12. *#21# -Allows you to check the number that "All Calls" are diverted to.
13. *#2640# -Displays security code in use
14. *#30# -Lets you see the private number.
15. *#43# -Allows you to check the "Call Waiting" status of your phone.
16. *#61# -Allows you to check the number that "On No Reply" calls are diverted to.
17. *#62# -Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to.
18. *#67# -Allows you to check the number that "On Busy Calls" are diverted to.
19. *#67705646# -Removes operator logo on 3310 & 3330
20. *#73# -Reset phone timers and game scores.
21. *#746025625# -Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible.
22. *#7760# -Manufactures code.
23. *#7780# -Restore factory settings.
24. *#8110# -Software version for the nokia 8110.
25. *#92702689# -Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again.
26. *#94870345123456789# -Deactivate the PWM-Mem.
27. **21*number# -Turn on "All Calls" diverting to the phone number entered.
28. **61*number# -Turn on "No Reply" diverting to the phone number entered.
29. **67*number# -Turn on "On Busy" diverting to the phone number entered.
30. 12345 This is the default security phone lock code.
Nov 18, 2011 | Nokia 7610
Memorycard pasword remove
Hi, We have followed the advice given on your website but still cannot divert our phones to a mobile, any other things we could try? We have five phones in total Thanks Kirstie
I don't know where are you from? But in some countries the telecom service provider do not allow to divert phone calls to mobile or another network. The service provider will not tell you. It is like a war within & the customer suffers. Calls can be diverted easily if you have landline & mobile service from the same service provider. You can make sure of this from the service provider. Even in internet broadband services they block each other's website to make life difficult for customers.
Aug 03, 2011 | Panasonic KX-T7633 Corded Phone
How to turn off call forwaring
My dear,
All you have to do is, enter #33*0000# and dial from your phone. hope this helps
Jun 07, 2011 | Motorola Mobility CITRUS Smartphone
When i put the memory card into the x3 phone nokia, the phone is turn off immediatle. i need a solution
This codes works most of NOKIA series.
Nokia code Code function
*3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5%
*#4720# With this Nokia code you can deactivate the Half Rate Codec
*#147# This lets you know who called you last (Only vodofone)
*#21# This phone code allows you to check the number that "All Calls" are diverted to
*#2640# Displays phone security code in use
*#43# Allows you to check the "Call Waiting" status of your cell phone.
*#67705646# Phone code that removes operator logo on 3310 & 3330
Cheerup and Be Happy always.
Apr 13, 2011 | Nokia X3 Cell Phone
COUNTRY CODE
hi you try this code...
These Nokia codes will work on most Nokia Mobile Phones
(1) *3370# Activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5%
(2) #3370# Deactivate Enhanced Full Rate Codec (EFR) OR *3370#
(3) *#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time.
(4) *#4720# Deactivate Half Rate Codec.
(5) *#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type.
(6) *#9999# Phones software version if *#0000# does not work.
(7) *#06# For checking the International Mobile Equipment Identity (IMEI Number).
(8) #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w"and "+" symbols).
(9) #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w"and "+" symbols).
(10) #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w"and "+" symbols).
(11) #pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" Go to Topand "+" symbols).
(12) *#147# (vodafone) this lets you know who called you last.
(13) *#1471# Last call (Only vodofone).
(14) *#21# Allows you to check the number that "All Calls" are diverted to
(15) *#2640# Displays security code in use.
(16) *#30# Lets you see the private number.
(17) *#43# Allows you to check the "Call Waiting" status of your phone.
(18) *#61# Allows you to check the number that "On No Reply" calls are diverted to.
(19) *#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to.
(20) *#67# Allows you to check the number that "On Busy Calls" are diverted to.
(21) *#67705646# Removes operator logo on 3310 & 3330.
(22) *#73# Reset phone timers and game scores.
(23) *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop
(24) *#7760# Manufactures code.
(25) *#7780# Restore factory settings.
(26) *#8110# Software version for the nokia 8110.
(27) *#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again. ( Favourite )
(28) *#94870345123456789# Deactivate the PWM-Mem.
(29) **21*number# Turn on "All Calls" diverting to the phone number entered.
(30) **61*number# Turn on "No Reply" diverting to the phone number entered.
(31) **67*number# Turn on "On Busy" diverting to the phone number entered.
(32) 12345 This is the default security code.
Dec 25, 2010 | Nokia 1100
I want codes
NOKIA Codes
#3370# Deactivate Enhanced Full Rate Codec (EFR) .
*#4720# With this Nokia code you can deactivate the Half Rate Codec.
*#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type .
*#06# For checking the International Mobile Equipment Identity (IMEI Number) .
#pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) .
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) .
*#147# This lets you know who called you last (Only vodofone).
*#1471# Last call (Only vodofone) .
*#21# This phone code allows you to check the number that "All Calls" are diverted to.
*#2640# Displays phone security code in use .
*#61# Allows you to check the number that "On No Reply" calls are diverted to .
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to .
*#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible .
**61*number# Turn on "No Reply" diverting to the phone number entered .
**67*number# Turn on "On Busy" diverting to the phone number entered .
12345 This is the default security code .
press and hold # Lets you switch between lines.
Author : JBJ
Dec 20, 2010 | Nokia E63 Cell Phone
Calls are all being directly forwarded to voice mail, checked forwarding settings not able to disable
Hello
First of all, make sure the phone isn't set in airplane mode. Try *73 to make sure there's not an automatic call forwarding accidentally set.
leave the phone on and then pull the battery. Replace it and turn the phone back on. If you're still having issues,Would you be willing to factory reset the phone and try again? I would not expect a reboot to fix it but perhaps a master reset should.
Dec 13, 2010 | Motorola Mobility CLIQ Cell Phone
Grandstream GXP-2000 IP Phone Logo
2,291 people viewed this question
Top Grandstream Computers & Internet Experts
Taxpert
Level 1 Expert
Dave
Marvin
Marvin
Are you a Grandstream Computer and Internet Expert? Answer questions, earn points and help others
