Question about Toshiba 47LZ196 47 in. HDTV LCD Television
Our toshiba rezga 47lz196 colour is off. There doesn't seem to be any red. All the skin tones are green. Blue shows up but all the other primary's are green. We have green, blue, yellowish, black and white. Any ideas.
  • Toshiba Master
  • 8,457 Answers
There are only two possibilities for this problems for this tv.One: the tv incomming broadcasting signal cable wire that is plugging into ur tv Tuner signal board could be bad.U can test this out the incomming broadcasting signal cable wire is good or bad pretty easily by just plug it into another tv to find out the incomming signal cable wire is bad or good.Two: If the tv incomming broadcasting signal cable wire is good by plug it into a another tv.Than ur tv the tv Tuner signal board is the causes and the problems.The tv Tuner signal board CPU chip is bad.U can do some mechanical work like take things aparts and putting it back together again?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Posted on Apr 27, 2011
Anonymous
SOURCE:
TV green colour
it seems issue with the tuner.
Jun 24, 2008 | Televison & Video
I see no red and green colors on screen projected by pjtx 100, the rest of the colors are visible.
If you are using a component video cable (Red, Green, Blue) you may simply be missing the Red cable. It may not be fully plugged in.
You can verify that this is the case by: 1. Unplugging all video cables 2. Plug in the green cable, you should see a black and white image. 3. Plug in the blue cable, you should see some colours coming through. 4. Plug in the red cable, you should see all colours properly.
If not, unplug the blue and red cables and plug the blue cable into the red port. The colours will look incorrect, skin tones will be blue. If the colour comes through the problem is the cable. If the colour does not come through, the problem may be the projector.
Feb 28, 2011 | Hitachi PJTX100 Multimedia Projector
I have a toshiba 56hm195, colors skin tones are washed out, reds
I'm having the same problem; have you found any solutions yet?
Dec 22, 2009 | Toshiba 56HM195 56" Projection HDTV
Hi there ive got a toshiba 43vj13p very blue picture
Hello, you can then buy a replacement lamp or lamps Toshiba 43VJ13P? Thank you
Dec 21, 2009 | Toshiba 53H71 53 in. Rear Projection...
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
GVA TV
I have a GVA TV problem with his remote First four minutes it work properly then stop working. Batteries replaced many times still same problem. Give the solution.
Jan 12, 2009 | Televison & Video
53HX71 showing lots of green
im thinking blue lamp if whites look pink thats telling me theres not enough blue.
Dec 05, 2007 | Toshiba 53HX71 53" Rear Projection...
Get into service mode
if it cannot be adjusted then there is a problem in tv. as your green color is absent you will get red+blue=purple your problem is in green video ckt please check 1 sypply to green cathode ckt 2 loose contact in crt base 3 loose signal connector 4 check components related to green cathode& green video tr. itself 5 check for green signal is coming to green video section from processor. 6 signal processor ic if you are not tech person get it done by skilled tech. it is a common problem. it is a not a major problem. please check
Sep 30, 2007 | Televison & Video
Toshiba 47LZ196 47 in. HDTV LCD Television Logo
205 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
