SOURCE: my washing machine is not spinning anymore
Do not think this is the problem. Make sure pumping out properly,,Could also be motor brushes if its an older machine...
SOURCE: LG INTELLOWASHER DD 7KG
You may need to have the door switch replaced but before that should be done, make sure the wire connector is securely in place.
SOURCE: lg washing machine wm-1460fhd door locked wont
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
SOURCE: How do I replace my door boot seal/door gasket on
There are 2 springs attaching the door boot. The springs are really tough but there are 2 separat tools for each spring. Use the tools to remove & install. It's tough but can be done.
