Are you sure that isn't "internal" memory card is full message?
Sometimes, when "internal
memory card is full" there is no more space in the camera's internal
memory. Your camera has 16 MB of internal memory. The number of pictures
you can store depends on the picture size setting you have selected on
your camera. Keep in mind that the
camera always uses internal memory, even if a card is installed (auto default).
If really, the problem is in the "SD memory card", I suggest make some backup all files and reformat the SD. Try formatting it in the camera, there should be a process in your owners manual for doing this; donw formatted SD in your computer, isn't good.
Hope helps.
SOURCE: I put a new memory card in the camera and it says
You need to eliminate the pics from the internal memory. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your card and do the "format" thing again for the card. Everything should be normal now.
SOURCE: camera says my memory is full
It can only take a 2gb memory card. anything higher than that it won't be able to use. The reason it's saying the memory is full is because it's still using the built in 15mb (something like that)
SOURCE: I have a 2GB SD Memory card thats won't format and says its full
Are you formatting it in the camera or a computer? It needs to be done in the camera it's being used with.
SOURCE: Brand new memory card
I have the same problem with the same camera. I checked other sites and it seems that the C330 takes only SD cards up to a max of 1GB. It won't read SDHC cards and it won't read SD cards greater than 1GB.
