The frig has a defrost timer which activates an electric element which cyclially defrosts the evaporator in the freezer.If either the heating element or the defrost thermostat are faulty the freezer evaporator will freeze solid not allowing cold air circulation to the rest of the frig.
At a suiteable time empty fridge contents into insulated containers and turn fridge off at powerpoint and allow to fully defrost leaving doors open.The evaporator coil in frostfree is normally located behind the rear panel of the freezer.If you do not have defrost heater it will take 3-4 hrs for complete defrost.
After defrost turn fridge back on and make sure items to be returned to freezer are free from moisture and ice and keep freezer open for minimum of time as moisture will start building up onthe evapoator.
If the fridge works ok for a couple of days and the the original problem returns the problem is with defrost thermostat or defrost heater
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
