the drum is in cartridge with toner. So if you buy new cartridge ( genuine or repaired ) you can use your MFP.
You must have on mind that you have 4 drum/toner units inside - Bk, C, M, Y. To be sure which one is needed to be changed refer to your problem, which I presume are lines and spots on printed paper. i.e. if the lines are yellow, you need to replace yellow cartridge.
The crg. No. are:
CB540A-Bk
CB541A-C
CB542A-Y
CB543A-M
Remanufactured one are from 50USD to 70 USD depending on quality.
The each cartridge goes about 2000-2500 prints/copies.
Hope that helps!
