i think that is a good time to make some ice.
and depends what temp. you have the freezer setup to.
the colder the ice the longer it takes to make ice.
if you have to or need more information try this
hi rudy.many reasons for not making ice but first go through some basics.1-turn on ice machine/or leaver down 2-check water in ice tray 3-if empty fill manually .4-ice drops once and stops.then5-not filling with water. 6-check pipes and inlet valve.good luck ali
HI.BASICS FIRST .1-water on 2-lever down on ice mach.check for water in ice tray 3-if empty manually fill up.4-ice drops once and stops.5-check inlet valve.hope this helps. good luck.Ali
don't know if you solved this, but we had a similar situation.
Leave the machine off until all the ice melts off the cups.
You need to take off the front cover and adjust the sizing down a good quarter turn. Let it start making ice and make sure all the ice drops. If it doesn't size it down more. If it all drops and the ice is too thin, turn it up VERY little (2° or so). Keep adjusting until you get the size you want but still get all the ice to drop.
FROM WHAT I UNDERSTAND IS THE FRIDGE IS MAKING ICE BUT JUST NOT MAKING VERY OFTEN.THE PROBLEM COULD LIE WITH THE ICE MAKER AS YOU SAY THE ICE IC CLOGGING UP THAT COULD MEAN THAT THE ELEMENT IS NOT SEMI MELTING IT FOR IT TO DROP INTO THE HOPPER.BEST YOU HAVE A TECH SERVICE AND REPAIR THE ICE MAKER.
hi thanks for the question probably have a problem with ice maker the timer in ice maker is not advancing to the drop off cycle need a new ice maker thanks the appliance doc
