Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
wendy atkins Posted on Aug 04, 2017
HELP I tried to reset my bosch exxcel srs45e32gb/09 following the instructions now i get 18 come on the time panel. i reset it, it goes to 0 i switch off (also at mains) and when i switch back on it still saying 18 in the panel also every one of the lights are on. I let it run for the 18 and it still comes on 18. also P1,2,3,4, comes on depending which button i press. any ideas what else i could try?
5 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Dec 30, 2007
SOURCE: Bosch SHU5318: Water wont start washing
if it hums when you are in the wash phase then something is jamming the wash impeller like broken glass tooth pick found a necklace in one one time i think replacing the control board fixed the other problems on most washers the drain pump is separate from the wash motor haven't worked on bosch so not sure take off the lower spray arm and go down till you get to the impeller then do what you have to do clear it or replace wash motor
Deep Diver
  • 14 Answers
  • Posted on Jan 17, 2008
SOURCE: bosch aquasensor diswahing machine
To reset the board so as the times will go back to factory settings.
Turn appliance on press both buttons that have the two dots under, the display will then go back to zero. Shut the door and allow appliance to reset itself. This normally takes about a minute, whilst it's doing this the pump will be running.
Hope this helps
Deep Diver
Carmen Mikulic
  • 415 Answers
  • Posted on Sep 25, 2008
SOURCE: Bosch Exxcel Dishwasher operating instructions
hi there,
can you supply the complete model # for me and also an e-mail address and i will e-mail you the pdf file.
thanks
Carmen Mikulic
  • 415 Answers
  • Posted on Oct 24, 2008
SOURCE: Bosch Exxcel Max USER MANUAL
hi there,
if you send me your e-mail address, i will forward you the file in .pdf.
thanks,
c
Anonymous
  • Posted on Nov 09, 2009
SOURCE: Bosch Dishwasher SGS43E02 Exxcel.
Obviously a faulty connection. Lots of switching off and on and holding down the buttons eventually sorted it!
8helpful
2answers
Instruction manual for bosch exxcel dishwasher
Hello hazenchris
Please click the link below to download the user manual for the Bosch SRS45E02GB/18.
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=qcbpLlccdcso0pdmdb---03K&UMOBID=qcbpLnecdcso0pdmdb---03K
You will need to have Adobe Reader or another PDF file viewer installed on your PC to view the manual:
http://get.adobe.com/uk/reader/
If you need assistance with your Bosch dishwasher, please let me know.
Regards,
BElectric
4helpful
I want to reset my exxcel dishwasher please tell how.
many thanks for your reply, i had miplaced the instruction manuel but now it has been found (in the shed). now i know what to do.....
Neff dishwasher stuck on wash cycle
sounds like the relay on the control/power module has jammed there should be a reset position on the board it usually involves pushing two selection buttons at the same time try resetting it
My bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Wont drain!!!
Check first the drain lines and the drain pump.
If the drain pump is working, and there is no problem in there, then the problem is usually because the water level switch activated by the floating sensor is stuck.
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
