Question about LG WM2016C
I have an LG Front Loader Washer, Model WM2016C, it is reading error code LE.
  • rsteif May 03, 2011
    I have always used Tide HE. never overloaded it. According to the $160.00 tech that came out yesterday, he said it was the bearings, (the rear drum and bearing assembly). After he changed the HALL sensor, which was fine. He said it would not be cost effective to fix, because it was a 2 man job and we would have to pay for the labor, and that exceeded the worth of the machine. What a waste of $750.00 for a 2 year old machine that was barely used by 2 person household.
  • LG Master
  • 43,501 Answers
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Posted on Apr 30, 2011
  • D. Floyd Kolb
    D. Floyd Kolb May 03, 2011
    I really can't say one way or the other with out actually looking at the machine myself...but what he said is a possibility...they sure don't make 'em to last anymore...and it sure does tick me off when I have to deal with ********** customers and they are RIGHT!!!! They have evey right to be upset!!! I'm with you on this!! Wish I could make a difference but I can't...
Anonymous
SOURCE:
Have a LG front loader and it's giving me LE error code and water is in the machine..... What is LE???
For LG's 'LE' stands for 'Lock Error' indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
We cannot help any further from a distance.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 04, 2011 | LG WM1812C Front Load Washer
How do you clear the le error code on a front loader so it will run?
Hi Wendy just read your posting.Unfortunately LE means the Hall sensor on your motor or motor is faulty. To clear the error code you need to either change the Hall sensor or motor.Most of the time the fault is the Hall sensor.Please reply for further help.Looking forward to your reply.
May 24, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What does the LE code mean on the LG front loading
The main cause for this error code is because you used too much or the wrong kind of detergent in your washer. This code is set off by too much suds in the washer. Not only will this set off the alarm code, but it may also cause your washer to leak and even start to have a bad smell from the dampness getting where it should not be.
OR
LE is a locked motor error. Not to worry as 95% of the time it is just a bad hall sensor (the motor position sensor). For your model the part number is 6501KW2002A.
Please check the below link for an detailed article about LE error code
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
COURTESY:HEATMAN101 - A senior and experienced expert of fixya
Jun 06, 2010 | LG WM-2277HW Front Load Washer
ERROR CODE LE ON LG FRONT LOAD WASHER
May 28, 2010 | Washing Machines
Getting a E1 code one the front panel and will not finish the cycle
There is not a reference for an E1 error code.
The listed LG error codes are:
IE, UE, OE, FE, PE, dE, tE, LE, EE, and PF.
May 18, 2010 | LG WM2016C
LE error code on LG WM0642 FL washer
LE is a locked motor error code.
It is usually associated with a loose motor connector wire or a defective Hall Sensor.
Mar 08, 2009 | LG WM-2277HW Front Load Washer
LG Front load washer LE error code
You can order parts by your location by CLICKING HERE
Nov 21, 2008 | LG WM-1832C Front Load Washer
Error message displayed on LG tromm washer model # wmt2778w
Flashing UE - The display shows:
• Load is too small.
• Load is out of balance.
• The washer has an imbalance detection and correction system. If individual heavy articles are loaded (bath mat, bath robe, etc.) and the imbalance is too great, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and the error code will be
displayed.
Possible Solution
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
• Control error.
Nov 07, 2007 | LG WM-2277HW Front Load Washer
LG WM2016C Logo
1,660 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
