Epson Perfection V500 Flatbed Scanner Logo
Posted on Apr 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I get 2/3rds of the way into installing the software and driver with the set-up disc that came with the Epson V500 Scanner, then a Error Pop Up message appears saying the following. Could Not Copy Files Make Sure the Target Disc is not Read-Only I tried downloading the software and driver from the Epson website, and still the same problem happens with the error message. What am I doing wrong? I am running Windows XP Professional (32bit system)
Steve F
Level 3:
  • Master 1,361 Answers
  • Posted on Mar 08, 2015
Steve F
Master
Level 3:
Answers
1361
Questions
Helped
567099
Points
3788
Check that it is installing to the correct file. Normally C Drive "Program files" I would suggest you go to the control panel and locate and completely uninstall the Epson scanner program first. This will give you a clean install. Check that during the installation, the disc may ask where you want the program to be installed. If it has a suggestion, let it instal itself, where it thinks is best.
4 Related Answers
xptareq2000
Tareq Bin Mostaq Mostaq
  • 1449 Answers
  • Posted on Aug 27, 2009
SOURCE: Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Anonymous
  • 1015 Answers
  • Posted on Sep 24, 2009
SOURCE: Software won't load on computer
Try this link
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58611&prodoid=53540925&infoType=Downloads&platform=Windows
This page has all the drivers and software for your scanner. Download and install.
Anonymous
  • Posted on Jan 16, 2010
SOURCE: Epson 4490 photo scanner drivers will not install on winxp system
I'm running Windows XP and have had similar problems - where the install process informs of a problem (at beginning of install) and to "Restart and try again".
Eventually resolved issue by selecting "Custom" install, then ticking all the selection boxes as had been automatically done in "Recommended" install - then continue with the install.
All sections of software now installed correctly.
Anonymous
  • Posted on Oct 18, 2010
SOURCE: Software installed successfully. Scanner will
Try shutting down your computer and then unplug from the power source. Wait a minute then plug it back in and turn on the computer.
Accept the driver installation even though it does not pass Windows Logo testing. Just accept it and continue with the installation.
Epson v500 Photo scanner was working but now gives a red light and whirring noise when opening the app installed on Mac - gives warning "cannot properly connect with scanner".
Here are some troubleshooting steps you can try for your Epson V500 Photo scanner: Check the connections: Ensure that your scanner is properly connected to your computer and turned on. Check the cables and ports for any damage or loose connections. Restart your computer: Sometimes, restarting your computer can fix communication issues between your scanner and computer. Reinstall the scanner software: Try uninstalling and reinstalling the scanner software on your computer. You can download the latest software from the Epson website. Check for updates: Make sure that your scanner software and computer operating system are up to date. Try a different USB port: Plug the scanner into a different USB port on your computer and see if it makes a difference. Reset the scanner: Turn off the scanner and unplug it from the power source. Wait a few minutes and then plug it back in and turn it on. If these steps don't resolve the issue, it's possible that there may be a hardware problem with the scanner that needs to be repaired.
Epson v500 scanner says "No scanner selected" message with Mac Desk OS X
Have you installed any Printer software for this epson v500 OfficeJet 8500 Printer or just connected it for the first time
Get an error report when trying to load driver
I have many years of repairing Canon scanners and here is my suggestion to you.
I would first go to Epson's website and download their latest driver. Before you install those drivers disconnect the cable that goes from your scanner to your computer. Then install the driver, when the process completes or if your prompted to by the software then connect the cable from the scanner to your computer. Your scanner must be powered on when you do this so your computer sees the scanner. You will get a pop up window saying a new device or new drivers are being installed at this point. The point that the software completes installation I reboot (restart) the computer and your scanner should be ready to use then.
I hope this helps you out.
4helpful
I'm trying to install my new Epson Perfection V500 Photo Scanner. I followed the instructions. The software installed . When I turned on the switch a loud grinding noise occurred and t I get an...
Its the lock mechanism under the lid , lift the top to the scan bed and look at the lower right hand side of the inside of the lid there is a grey swithch , move it to unlock! Voila , fixed.
Software installed successfully. Scanner will not scan. Troubleshooting Assistant insists an error occurred during installation of device. It also says Epson Perfection V500 Photo does not pass...
2answers
By using the epson v500 photo I get the following massage: "Please remove the document mat and/or close the document cover" Off course I remove the mat and de document cover is close. I send the scanner to...
Possible driver issue. You have to reload the twain driver.
To uninstall the twain driver, please follow the ff instructions:
- Trash epson scan and epson scanner monitor from the harddrive
- Go to the library, then application support. Trash epson scanner module.
- Go to the library again, then image capture. Trash twain data sources.
- Go to the hd. Click on users. Click on the name of your computer. Click on library, then preferences, then epson. Trash epson scan.
Empty the trash and restart your mac.
When your mac is fully back on. Go to http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88368&prodoid=63070478&BV_UseBVCookie=yes&infoType=Downloads&platform=Macintosh&x=23&y=13 and you are now ready to install the Scanner Driver and EPSON Scan Utility v3.27.
Computer no longer recognizes my scanner
If you are using a multi port USB adapter that allows you to plug many devices into one USB port it may interfere with the scanner. Try uninstalling your Epson driver then download the newest one from the Epson website. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88368&prodoid=63070478&BV_UseBVCookie=yes&infoType=Downloads&platform=All&x=27&y=14
Install the newest driver first then plug your scanner into a single USB port on the computer instead of the multi port.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
