Symbol PDT 3110 Portable Terminal Logo
Posted on May 01, 2011
MY PDT3110 LOCKED UP NOT RECOGNIZED - Symbol PDT 3110 Portable Terminal
How do I unlock my amazon prime account?
need to notify amazon about account information --on wrong site this is fixya a repair forum
My phone worked fine now it says not registered on mobile network
remove the sim card and start the phone, keep it on for 10 seconds, switch it off, remove the battery and again keep it off for 10 seconds. Install the sim and switch it on. Hope it will help. Make sure the network searching mode is selected to automatic
How do I fix my phone if I get the message" Not registered on Network"
There may be few possibilities like the network not recognized,
locked with some other network,firmware not updated etc...
Network Not Recognized:
First, go to Settings-->Then go to Wireless and networks.-->Then Tap Mobile Networks (If mobile networks not found then tap More settings and then find and tap Mobile networks).-->Now tap Networks operators.-->After complete searching.... Then select your Network Operator (Like Vodafone, Idea, AirTel, etc.)
That's it, problem solved.
Locked with someother Network:
I suggest you can approach Simpleunlocking.com and specify the country,locked network of ZTE .Based on the availability you can get the permanent unlock code along with free instructions.
UN-updated firmware or software:
Select Software Update and Wait For It to reboot and Completed Update Completed!
Cannot make a phonecall, message is not registered on network
I suggest you can approach Prounlocking.com and specify the country,locked network of ZTE .Based on the availability you can get the permanent unlock code along with free instructions.
I think mine is the e260 - 2 gig sansa. The last time I turned it on, it resumed playing the album that had been playing the previous time I used it - as normal. When the album finished and I tried to...
Resetting the device:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
Ipod is locked and will not be recognized by the computer.
I would imagine what your friend told you is correct. The only other thing you can try is to hold down the menu and the middle button for 5 seconds to reset it. Apart from that it would definately be a hardware issue.
Hope this helps
Craig
Unlocked tapes recognized as locked
this is probably due to a stuck microswitch in the tape drive unit as the locked tag presses a microswitch when loaded it is possibly these microswitches that are failing, as one of the switches detects if a tape is loaded and the other detects is a tape is locked, so problems with these switches would mean that it cannot detect if the tape is loaded properly.
2answers
I have a maxtor icon with a lock on it. I click on "unlock" and nothing works i have maxtor one touch II 300 GB, i'm using windows XP SP3 my maxtor is locked. It is only recognized on my computer under...
Have you tried right clicking on the drive and going into properties. Click on security option and make sure that all the permissions for the drive are active with the exception of special permissions. Also look at the advanced security settings and make sure that you have full control permissions. Hope this helps.
1helpful
2answers
My etec mp3 player will not do anything. When I turn it on, the hourglass appears, but that's it. I will not play, charge, or be recognized by my computer. What's wrong? I've onlt had it for about 5...
The hourglass appears but then nothing.
Connecting on my computer is recognized and I see the my music files. Trying to format or delete files i get a " file are locked".
Top Symbol Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
