Question about Whirlpool GSC9455 Top Load Washer
Washer will not drain after wash cycle or the spin cycle
My speed queen washer stops after the wash cycle, will not drain. Timer control keeps running and than it goes into a spin cycle with water in the washer. As the water swirls around it eventually gets pumped out and the spin is normal. Same happens after the rinse cycle. Any help would be appreciated
  • Anonymous Mar 19, 2014
    washer goes through cycle, apparently all water is out, but pump keeps running
    Novelist:
  • 177 Answers
Check to see if your pump is slightly plugged with a sock or ?
Your top loader should pump out in about a minute and a half when totally full of water.
Posted on Aug 12, 2008
6ya staff
SOURCE:
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Why does my washer stop in cycle
Raise and lower your lid six times to reset timers.
Sep 30, 2017 | Speed Queen CTSA0AWN Front Load Washer
Washing machine goes thru the wash cycle then it stops, if I lift the door it starts again ,than stops. lift the door it starts than stops
It could be your out of balance switch is getting tripped before you try it again put in the spin cyc and see if it spins and drains the water if it does a odd sized load could be causing the failure.
Apr 09, 2011 | Speed Queen AWN542 Washer
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
Speed queen top load washer does not agitate properly
you need to see if the motor turns one direction during wash and the other during the spin. If so, your gearbox is faulty and needs replacement. If motor only goes in one direction at all times, then very possible, the timer is faulty.
May 29, 2010 | Washing Machines
Washer is skipping cycles
Many select their own possitions for the timer to reduce water usage. Often it is border line where the spin cycle is activated. Try from the beginning, and if it still malfunctions, not question, the timer will need to be replaced. (very basic machine with no noncense activations).
May 23, 2010 | Speed Queen AES17AWF Electric Dryer
28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Aug 31, 2008 | Speed Queen AWS52NW Top Load Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
Whirlpool GSC9455 Top Load Washer Logo
365 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
