Cars & Trucks Logo
Posted on May 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rear door on 06 jetta wont open - Jetta Volkswagen Cars & Trucks
Anonymous
Level 3:
Guru:
  • Master 1,705 Answers
  • Posted on May 01, 2011
Anonymous
Master
Level 3:
Guru:
Answers
1705
Questions
Helped
402759
Points
5112
At a guess the outside handle has become detached from the linkage inside the door and you've got the child lock on as well.
Well to get the child lock off, you need a long fairly broad plastic strip, I've used the long side cut out of a plastic milk carton in the past.
Wind the window in the offending door down, then insert the plastic strip in the door gap underneath the handle, once in try the internal door handle, if it fails try again working your way down the door by widths of the plastic strip, trying the internal door handle as you go, with luck you'll have release the child lock by the 3-4th try.
Once open, its taking the inside door card off and re-attaching the linkage for the outside handle.
5 Related Answers
Anonymous
  • Posted on Sep 12, 2009
SOURCE: i have a VW 1996 jetta and sometimes it wont
probably the MKIII alarm acting wonky. the car will not start if the alarm won't let it. permanently disable it: http://faculty.ccp.edu/faculty/dreed/campingart/jettatech/alarmcentralhelp/alarmhelp2.htm
Anonymous
  • Posted on Jan 31, 2010
SOURCE: electrical problem with car 2006 Jetta 2.5
I appear to have an electrical problem. First my battery kept draining. I thought it was a problem with the radio so i pulled the radio fuse for a couple of days. Now as i drive it the drivers door (open) light comes on and wont go off. Today i went to get gas and the electric gas cap opener wont work.
John M Grubb Sr
  • 65 Answers
  • Posted on May 17, 2010
SOURCE: my 08 tahoe rear gate wont open how do i fix this
I found this URL on internet http://www.chefseattle.com/blog/site-news/suburban-rear-liftgate-wont-unlock-how-to-fix/ If your vehicle is similiar maybe it can help.
Anonymous
  • Posted on Jul 11, 2010
SOURCE: Need a rear door for 1998 VW Jetta. What other
I believe it's 1993-1998 that are the same. I'm not sure if you'd be close enough, but I'm actually parting out a 1998 Jetta, and have both rear doors. You can email me if you still need it. [email protected]
Anonymous
  • 252 Answers
  • Posted on Mar 01, 2011
SOURCE: Rear hatch door on 06 caravan sxt beeps and wont
It needs a latch...I am chrysler level 2 tech and have changed before with same problem...
It also happens to certain jeeps with rear hatch...although it isnt a recall yet but it should be.
The internal release mechanism wears at the pivot eventually wont open at all but should have a emergency release button at inside center..........Hope this helps Metalpoet
Power liftgate will not open with remote, instrument panel control or button in rear cargo on lincoln mkx
It can be faulty switch or its issue with lift gate latch.Its got stuck up hard or cracked inside.It has to be inspected.-----------
There are few help links with proper solutions for these problem.I suggest you to refer the links.
Click the link below:----
2007 Mercury Mountaineer: Liftgate will not Unlock or Open? http://whoisbyme.blogspot.in/2012/06/2007-mercury-mountaineer-liftgate-will.html
Adjust Hydraulic Lifters? http://schematicsdiagram.blogspot.in/2012/04/adjust-hydraulic-lifters.html
How to open rear lift gate? http://repairhelpcenter.blogspot.com/2011/12/how-to-open-rear-lift-gate.html
--------- Power Liftgate Shuts Down http://whoisbyme.blogspot.in/2012/07/power-liftgate-shuts-down.html
------------ Power Lift Gate Will Not Remain Open http://whoisbyme.blogspot.in/2012/07/power-lift-gate-will-not-remain-open.html
----------- Power Lift-gate will not Operate http://whoisbyme.blogspot.in/2012/07/power-lift-gate-will-not-operate.html
------------- Liftgate will Not Stay Up Open? http://whoisbyme.blogspot.in/2012/07/liftgate-will-not-stay-up-open.html
---------------- Rear Door will not open http://whoisbyme.blogspot.in/2012/07/rear-door-will-not-open.html
------------ 2000 Toyota Corolla: Rear Door wont open from outside or inside? http://whatisbyme.blogspot.in/2012/05/2000-toyota-corolla-rear-door-wont-open.html
These details will help.
Thanks.
2006 jetta door wont open from inside or outside
link connector broken inside door, Remove door card and repair
Rear hatch door on 06 caravan sxt beeps and wont open with remote or overhead controls. I have to manually open with alot of force. Any ideas on what is happening and how to fix
In the fuse box on 06 Jetta TDI, which fuse is for interior convenience plugs.
i think it's in the fuse box on the drivers side,the one only accessable when you open the door. its #24 ?? a white 25 amp. If im wrong let me know please
Rear door will not open
after you find a way of opening it. I suggest you get to the inner boot door panels and remove them to expose the lock and manually open it.
After this i think your problem lies in the wiring. chase back the cables that feed the door lock and you more often will find a fatigued cable torn or broken. a common occurance to my Montigo Estate.
AndystUK
1helpful
My rear lid wont open on my 2001 vw jetta 2.0L
central locking device on the boot is not working and needs replaced
2helpful
2answers
Electrical problem with car 2006 Jetta 2.5
have you checked the fuses make sure they are not burned.its usually the red but check all of them.
Back right door of 04' jetta wont open
or your conector is disconected or your electric motor is broken both thing you need to take off your doorpanel to take a look
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
