Question about JVC XV-N320 DVD Player
Dvd player says no disk - JVC XV-N320 DVD Player
    New Friend:
  • 32 Answers
First try multiple disks. If another disk works then problem solved, you have a bad disk. If that does not work try to gently blow dust away from the lens.
Posted on May 02, 2011
    New Friend:
  • 35 Answers
Does it read other disks?
try a few difference DvD's.
if other disks work, the disk you want to read is broken.
if other disks do not work, your dvd player is broken and you should get a new one or contact JVC if it is still under warranty.
6ya staff
SOURCE:
Sanyo 500 tries to load dvd but won't play dvd
Does that specific DVD work in some other DVD player?
Does that specific DVD work in the DVD-drive in your computer?
Dirty disk?
Feb 15, 2014 | Sanyo DVW-5000 DVD Player/VCR
Says "No Disc"
If you have put a dvd disk in your dvd player, and it says "no disc" then try cleaning it with a dvd cleaning disk. It could be that the eye of your dvd player is dirty. You can get a dvd cleaner at any department store.
If you have put a dvd disk in your dvd player and its a home made or "burnt" disk and your player says "no disc", it usually means that the disk is the wrong format to be played on your dvd player. Try another disk.
If you have not put any disk in your dvd player, and it says "no disc" its just telling you that there is no dvd inserted for it to play.
Jul 13, 2011 | Sanyo DWM400 DVD Player
When i burn a disk on dvd,it will not play on my dvd player?
Some DVD-players only read 'DVD-R' disks.
Some DVD-players only read 'DVD+R' disks.
Be sure that the "blank" disks you are using are compatible with your DVD-player.
Sep 22, 2010 | Dell Inspiron 530s Desktop Computer...
Program says dvd+r incompatible with toshiba dvd player
Some DVD players will read 'DVD-R' ("minus-R") disks.
Some DVD players will read 'DVD+R' ("minus+R") disks.
Some DVD players will read "both" types of disks.
So, if you're burning onto a DVD+R disk, you won't be able to "play" the disk on your Toshiba DVD-player.
Instead, buy "blank" DVD-R disks, and write on them.
Apr 05, 2010 | Computers & Internet
Suddenly my DVD player is saying "no disc" after trying to load DVD. Why isn't it sensing the DVD has been loaded?
When a DVD goes into DVD player it has to spin it and read it. If your DVD player is not reading the disk. The disk could be dirty. The DVD player might need to be cleaned. You could be trying to play a PAL disk on a NTSC player or Visa Versa. or the region coding might be wrong. Try playing a clean disk that you have played in it before. That might tell you if you need to clean the DVD player.
Mar 03, 2010 | GoVideo DV2130 DVD Player/VCR
The dvd player is not reading disk
is it a burned disk?.
some dvd players can read a disk You burned/made but only if the DVD player has AVI or DIVX logo on it.otherwise they Will Not play a burned movie/DVD..
I’m happy to help further over the phone at https://www.6ya.com/expert/william_83fc156eee2b555e
Aug 12, 2009 | Samsung DVD-P230 DVD Player
Dvd keeps reading no disc
It can be several reasons
1. Disk is upside down
2. Lens is durty. You will need to use CD/DVD cleaning disk for that
3. Disk is having diffrent region code or recorded in diffrent formate (for instance player playback disk recorded in NTSC, and you trying to playback disk in PAL formate)
4.Disk is recorded at higher speed (for instanse player markered X16, but disk is recorded at X24)
Good Luck
Dec 24, 2008 | Televison & Video
DVD player door won't open
took out the dvd player and inverted it and pushed the advance disk button . There was a disk stuck between the disk slots. The door opened and I removed the disk.
Sep 20, 2008 | GPX D2816 DVD Player
Play Back
Some DVD players can't read -R & -RW disks. When you finalize make sure it is in Video mode not VR mode so the recorded disk will be able to work in most other DVD players. Also some DVD players only read recorded disks rated up to 1x, 4x, 8x, 16x, or a combination of these speeds.
Nov 13, 2007 | Emerson EWR10D4 DVD Recorder
Player won't play any disks only says CANNOT LOAD DISK
change the way you connect the dvd player to your tv
Jun 22, 2007 | Sony DVP-NS305 DVD Player
JVC XV-N320 DVD Player Logo
181 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
