My digital camera error message comig lens error camera will shut down automaticly restart the camera my camera model no is canon IXUS 105 please provide me a solution
There is something wrong with your lens barrel. It can be anything from some sand/dirt that got inside in which you try using some canned air to blow out the particles while continually turning it on and off. Usually what it is from is the camera being dropped, even if it is in a case or inside a bad. The jostle or direct impact of the fall will break some small gears or tweak the lens off of alignment. If it was from an impact then you lens barrel needs to be replaced and in that case the repair cost are usually as much as getting a new camera. You can send it into Canon and get it repair for a flat rate. Sorry about your camera.
hi
if your lens looks bad like crooked, then you have to send to canon. They don't sell lens unit to local repair shop. but not serious problem (lens repairable) then bring to local repair shop. canon will charge you about $135, local repair shop would charge you $65
Thanks and good luck with you!
something has malfunctioned in the lens motor itself, unfortunately this means that your going to have to take the camera into a repair shop or send it back to canon for repair.
A lens error can be caused by physical damage to the mechanism that controls the lens, or debris that is interfering with the operation of the lens.
This article may be able to help you with a "do it yourself" solution. http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
In the event that your problem is due to physical damage and not just dirt or debris, you will need to take it to a local camera repair shop for troubleshooting-- though with most consumer digital cameras, labor and parts cost of a repair can easily exceed the value of the camera.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
So when its stuck you just push on the lens.
i know it sounds crazy, and it'll sound like you cracked it, but it really does unjam your camera!
try it!
