Question about Onkyo HT-S580 System
When i connect my onkyo ht-5300 system to my 60"sharp aquos tv with hdmi cables i get no video or sound
    Genius:
  • 1,340 Answers
You need press the input button on your TV's remote.Then you need to select the input setting for HDMI.On mine,there is also an HDMI 2 input so depending on how your's is wired,it could be either one but that should get you what you want to achieve.Good luck,Greg
Posted on May 02, 2011
  • jewaltonjr May 06, 2011
    I can't get my system to work but i am not stupid
  • Greg McCarthy May 06, 2011
    Well,according to your question,you didn't list anything about what you have or have not done and this is quite common on this site.However,I really do appreciate you calling me stupid for trying to assist you,which is also quite common.If you have any further questions,simply reply here and I will receive a notice and I will reply ASAP.Thanks,Greg
6ya staff
SOURCE:
No Audio in HDMI THRU Onkyo HT-R380 Receiver
Hello, I am sorry about your issue. I suggest that you contact us at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
Mar 03, 2017 | Onkyo HT-S3300 Theater System
I have a Bose home theater system and a Sharp Aquos tv. I'm trying to hook up the Bose dvd directly to the tv. Problem - tv only has HDMI input capability and Bose does not. I purchased a HDMI convert
Hello
You haven't given any description about the converter you bought. Please send me the model number and brand name of the converter did you bought. OK.
Nov 18, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Sound from Onkyo CD player well and fine. Then connected the Samsung DVD HT-Z310 to Video3 (L/R audio in, V-in from L/R Audio out and V-out of Samsung) but no sound or nor video on TV? Tried to fix it...
What am I missing here?
There are a lot of models mentioned in this post. What are WE discussing?
* A Samsung HT-Z310 is a Home Theater System.
* An Onkyo TX-DS777 is higher-end AV Receiver that DOES have a Video 3 input which accepts composite video and analog audio.
* An Onkyo CD player is irrelevant to the TV sound in any scenario.
* Unnamed TV.
I don't see any path in your narrative that would carry audio TO the TV. Is there an unmentioned HDMI cable in here somewhere? I see no other audio outputs on the HTZ.
Are you running the HT-Z310 through an Onkyo receiver to somewhere (?) else?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-Z310-Home-Theater-Systems-manual/id/23122dj393/t/2/
The fewer hops and inteconnects a given signal experiences between its source and your senses, the better. I always run the BEST video from any source to the TV first; the best Audio to the BEST audio electronics. If that helps.
Apr 03, 2011 | Onkyo TX-DS777
Why cant I supply my onkyo surround sound system
You need to assign the HDMI input(s) to the functions they represent, using the Front Panel Tuning/Preset control...
If you connect a video component to an HDMI input, you must assign that HDMI Input to an input selector in Setup.
For example, you could assign the “DVD” setting to “IN1”, and assign the
“CBL/SAT” setting to “IN2”.
Likewise if you use digital audio inputs...
Assigning the Digital Input
If there’s no sound, press the [DIGITAL INPUT] button repeatedly until sound is heard. The digital input is now properly assigned.
If you connect your DVD player to the AV receiver’s COAXIAL 1 DIGITAL IN, and your cable/satellite receiver
to the COAXIAL 2 DIGITAL IN, as shown, it’s not necessary
to assign the digital input.
Feb 12, 2010 | Onkyo HT-S5100 Theater System
Sharp Aquos LC-32GH5 and MacBook problem, HELP! I've recently bought a 32" Aquos and want to use it with my MacBook as a secondary monitor and screen for movies, etc... I bought all...
it sound like you did the right thing . The problem is the mac output for sound is bad or the TV input sound is bad.
try input a mp3 radio to the TV verify TV is working.
put an earphone to the mac to verify the mac out sound is working .
if both are working just tool around a little and you will get it. good luck
Aug 18, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No audio from my PS3 through the Onkyo 5100 7.1
if you are using an HDMI cable dont expect sound to come out (even thought HDMI carries both audio and video) the onkyo HT-s5100's Receiver is the HT-r560. the 500 models of the onkyo receiver does not allow HDMI to carry both audio and video. it only allows the video signal to pass to the receiver.
if youre using optical for audio w/c is what you need then these are the steps you need to follow.
*first make sure that the optical connections are ok at the back of the receiver.
*make sure that your DIGITAL INPUT is set to either OPT1 or OPT2 whichever optical input you used to connect the optical cable.
*then go to your PS# settings : go to sound settings / audio moutput settings/ select digital out (optical).
then enjoy.....ü
Jan 27, 2009 | Onkyo HT-S5100 Theater System
The picture via my Onkyo-sr674 has degraded
Hello, I am sorry about your issue. It sounds like your receiver may need to be serviced. Please contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you and advise of your options. Thank you, CB
Jul 10, 2017 | Onkyo TX-SR674 Receiver
Onkyo HTR500 no sound from the surround speakers or subwoofer
insted of running it thru the tv an to the reciver try doing it directly from the DVD player to the reciver just the audio jacks
Sep 08, 2008 | Onkyo HTR500 Receiver
Onkyo HT-SR750
Check out Onkyo's website: The HT-SR 800 description says "a separate audio connection is necessary" Maybe it is true for the --750 too.
Jan 01, 2008 | Onkyo TX-SR605 Receiver
Receiver won't put out sound to LCD Sharp aquos
I have the same problem with my Sharp Lcd and Onkyo 804. I believe one problem is that the TV can not accept dolby digital or dts digital audio signals through HDMI. It will play sound if it receives a PCM signal through HDMI. You can try switching the type of signal on the cable box settings and on the dvd player. I switched to PCM and got sound through the TV and the receiver. The problem is that PCM is usually only a 2 channel signal and Dolby 5.1 will sound better through the surround sound theater system. I have not found an absolute solution to this yet, but I am willing to not get sound through the lousy TV speakers in order to get top notch sound through the Onkyo.
Nov 12, 2007 | Onkyo TX-SR803 Receiver
Onkyo HT-S580 System Logo
219 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
