SMC Barricade 7004 Logo
Posted on May 03, 2011
How to enable dmz - SMC Barricade 7004
Anonymous
Level 1:
Scholar:
  • Contributor 160 Answers
  • Posted on May 03, 2011
Anonymous
Contributor
Level 1:
Scholar:
Answers
160
Questions
0
Helped
26699
Points
11
Should be an area within your router to do this.
Check out this site for the manual:
http://www.smc.com/index.cfm?event=downloads.doSearchCriteria&localeCode=EN_USA&knowsPartNumber=false&productCategory=1&modelNumber=881&partNumber=0&downloadType=8&os=20
1helpful
Where to set up the DMZ for a linsys wifi router Wrt54gsV7.2
To enable DMZ in Linksys wifi router follow the steps below:
  1. Access the router's web-based setup page. For instructions, click here.
  2. Click on Applications & Gaming.
  3. Click DMZ.
  4. Select Enabled and set the Source IP Address and Destination.
  5. Click to apply your changes. The DMZ feature of your router is now successfully enabled.
Im trying to change nat type 3 to nat type 2 on my smc router for my playstation 3? Whats the best way to go about that. thanks
  1. Open your web browser, type in the router's IP address (standard: 'http://192.168.2.1') and press enter.
  2. Click on Login, Advanced Setup, Firewall, enable it and click on apply.
  3. Click on DMZ and select Yes to enable DMZ.
  4. Enter the IP address of the PS3, which was assigned a static ip address to be kept under DMZ, and click on apply.
Hope this helps
How do I enable my UpNp and access dmz
Hi jbourke,
Please find the below steps,
1.In the internet explore type 192.168.2.1 and click on enter
2.you will get the belkin router setup
3.in your left hand side you will see the menu sysem settings at the last,click on it.It will ask for password leave it blank and click on submit
4.you will have the UPNP option enable it and click on apply changes
FOR DMZ
1.In your left hand side you will see DMZ,click on it,if it ask for password then leave it blank and click on submit
2.get the ip of the PS/3 it will be in the range of 192.168.2.
3.select the enable and type the ip address in the page and click on apply changes
Regards,
Ayyasam
4helpful
3answers
How to configure dmz on linksys wireless n router?
  1. Log into your router. (If you need help how to do it let me know!)
  2. Go to th "Application & Gaming" tab.
  3. click on "DMZ"
  4. choose "Enable"
  5. Enter the IP address of the computer you want to put in the DMZ.
  6. Click "Save Settings"
Some notes:
  • Putting a computer in a DMZ is pretty risky, because all ports to this computer are opened. Make sure that all recent patches are applied and your virus software is up to date! A more secure solution is to use portforwarding. (See this site how to do that for a specific software for your router.)
  • Your computer should be set to a static IP. For two reasons:
  • A) DMZ will not work if your DHCP server (your router) assigns at one point a different IP address to your computer,
  • B) If a different computer gets the Ip address assigned that you specified in your DMZ settings, then that machine is exposed.
If you don't know how to assign a static IP address, let me know and I walk you through the steps.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
3helpful
I have problem in downloading movies i Utorrent because my port is not open and i don't know the manufacturer of my DSL. Afaq DSL Shamel model 011. my speed is 2Mbbs.
you can enable the dmz of your modem to open ports. if you have an existing or 3rd party router, try opening the ports of your router by also enabling the dmz mode. also, check parental control of your modem. if there is, deactivate it. if you will be able to enable dmz and able to download movies, disable immediately the dmz for security purposes.
Ploblems with dmz-outside (webpage). pix
Remove this line:
static (DMZ,INSIDE) 10.10.0.0 10.10.0.0 netmask 255.255.255.0
You don't need a translation going from a lower security level to a higher one. You will also need a nat line for the dmz so that pc's on the dmz will be translated outbound. The only connection that will work on the dmz is the webserver when he's sending traffic outbound with a source port of 80. Something like:
nat (DMZ) 101 10.10.0.0 255.255.255.0
Other than that, it looks like it should be working. You've got permission, a route, and a translation. Maybe "clear local-host 10.10.0.2" to get rid of any bad xlates and try again. Check debg level syslogs, run packet captures, "clear asp drop" then "show asp drop" after an attempt?
I can't get DMZ on Westell F90-610015 to work.
NEED TO FIND THE DRIVER FOR WESTELL MODEL 6100F cAN YOU HELP?
Set your router to the DMZ?
You just need to access your router setup page then go to Firewall then select DMZ, To put a computer in the DMZ, enter the last digits of its IP address in
the IP field and select “Enable”. Click “Apply Changes” for the change
to take effect.
6helpful
2answers
How do I enable DMZ on the router?
1. Open your web browser, type in the router's IP address (standard: 'http://192.168.2.1') and press enter. 2. Click on Login, Advanced Setup, Firewall, enable it and click on apply. 3. Click on DMZ and select Yes to enable DMZ. 4. Enter the IP address of the machine, which was assigned a static ip address to be kept under DMZ, and click on apply.
Top SMC Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
