I have a sharp LCD tv 2years old it I will press the power button to turn it on and it will stay on for approx. 10 seconds and then turn itself off. I have even tried holding the down the pwer button for a few seconds to reset the tv but it still does the same thing
    Genius:
  • Televison & ... Master
  • 2,432 Answers
Hope it will help you, you may have problem with power supply and inverter area. low rated and leak capacitors can cause low output voltage on the power supply the tendency is the power to reset or turn off itself. just also considered bad component at inverter area, faulty connector and back light good luck.
Posted on May 03, 2011
Lcd tv won't turn on
It is possible that there has been an internal power supply failure. The red indicator merely means power is getting to the TV.
Dec 21, 2013 | Sharp LC-32LE340M MULTISYSTEM LED TV FOR...
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
Aquos model LC46D64U...approx 2 years old..Won't power up and get the power light flashing 3 times then the OPC light once..which is repeated...Any ideas...I believe this is quite common with Sharp TV's
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Oct 18, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My sharp tv wont stay on, it flashes green
Hi i have seen this before sharp hdtv's are known for having the internal power supply go faulty
Feb 01, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Jan 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV shutting off by itself
The power supply is going bad and should be replaced but for the cost you will pay for the repair you can buy a new TV. Get the extended warranty, it will pay for itself.
Aug 04, 2009 | Sharp AQUOS LC-42D85U 42 in. LCD TV
New JVC flat screen cuts off 10 sec. after cutting on
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
Mar 26, 2009 | JVC LT42P789 42 in. LCD TV
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
1. UNPLUG TV
2. HOLD IN VOLUME DOWN &INPUT buttons on TV
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
TV will not stay on
Sounds like you have a lamp error. Most likey there is something wrong with one of the lamps in the LCD itself, or you have a defective inverter.
Jan 21, 2008 | Sharp LC-15AV4U 15 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
