I T3530 electrolux drying machine when the machine starts working , the only fire flickered about 5 seconds the fire dies and the lights lit reset button , if pressed the reset button again his lights off and returned fire flame me ,
First thing you can try is to unplug the dryer for fifteen minutes or so. If that still bring up the error code then it is your board inside your dryer.
Thank you for your inquiry, Leanne!
From the information you have provided your Electrolux microwave is displaying an error code of "F1". I am showing that an "F1" error code is not valid. I would recommend resetting your microwave and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not correct your issue and you continue to experience an "F1" code please reconnect. -Matt
Thank you for your post, friend!
I understand that your Electrolux range is displaying an "E14" which is currently being displayed on your Electrolux range. Which means the display tail is missing or not connected. It could be a loose connector within the control panel. If not it could mean a replacement of the main control board or keypad.
I would recommend performing a reset on your appliance which you can do by disconnecting the power from your range. The best way to do that is by unplugging it or flipping the household circuit breaker for ten minutes. Hopefully this is helpful. -Matt
07 Machine heats incorrectly Check heating system and
thermostat.
