Computers & Internet Logo
Posted on May 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I lost the calculator of nokia 6300? I already update software. How can i again get calculator please say somebody.
samhelper
Level 2:
New Friend:
  • Expert 64 Answers
  • Posted on May 08, 2011
samhelper
Expert
Level 2:
New Friend:
Answers
64
Questions
0
Helped
10447
Points
147
Factory restore of the phone. on the menu go to phone options, then security options. Select factory restore. You will be asked for a security code which is 12345 if it was never changed from factory setup.
2helpful
2answers
I lost calculator from my Nokia 6300 phone
www.mobileheart.com/cell.../1129-Nokia-6300-Software.aspx
2helpful
I usung nokia 6300 and iam dowloding opera .opera not work my nokia 6300 and how to up grade my nokia 6300
hi may be the opera you are downloading is not suitable for your handset its better for you to not download opera
Nokia 6300 firmware update
Subject: how to update firmware for Nokia 6300 to the latest official version
I bought Nokia 6300b RM-222 with firmware version 4.71, but now the latest firmware is 7.30 (or any latter build). But Nokia Software Updater (link) told me that I already had latest firmware and refused to update my phone. Below I described the steps to upgrade Nokia 6300b RM-222 from version 4.71 (or any other version) to version 7.21/7.30 (or any latter build).
1. You need download and install NSU - Nokia Software Updater (http://europe.nokia.com/support/download-software/device-software-update/download#) and run it to ensure that all is ok! (don't forget to switch on and connect Nokia 6300 via USB with PC)
2. You need to download and install NSS (Nemesis Service Suite) (http://www.b-phreaks.co.uk/index.php?main_page=page_2), the latest version of NSS was 1.0.38.15 (select "Virtual USB Device" mode)
3. Close NSU if it's not closed and load NSS then click icon "Scan for new device"
4. Click icon "Phone Info" and button "Scan" inside it
5. If all is ok you'll see some lines with Phone Version, Phone IMEI and so on
6. Click button "Read" and remember your "Product Code"
7. If your want to clean your phone go to tab "Tools" and switch to subtab "Factory Setting", choose option "Full Factory" then press button "Reset" (NOTE!!! all personal data and settings will be cleared!)
8. Return to tab "Phone info" and type in the field "Product Code" the following code 0537621 (or any code from (http://www.expansys-usa.com/ft.aspx?k=96957)) for version 7.21, or code 0557624 (or any code from (http://www.a2phone.com/6300-rm-217-dp20-900-sw-0730exe)) for version 7.30, select option "Enable" then press button "Write"
9. Close NSS, run NSU
10. Now NSU should update firmware to version 7.21/7.30 (or any latter build) (http://europe.nokia.com/support/download-software/device-software-update/can-i-update)
11. Repeat stages 3 - 5
12. Type in the field "Product Code" the code that you remembered before, select option "Enable" then press button "Write"
13. Close NSS
14. Use you clean phone with new firmware!
2helpful
I lost my nokia 6300 Calculator on my mobile system
RESTORE MOBILE SETTINGS OR ELSE UPDATE THE SOFTWARE
11helpful
I lost calculator application from my Nokia 3110 mobile
for this you have to flash your phone or update your software.
Lost of calculator in nokia 6300
do as follows menu> extra > calculator
or try menu > organiser > calculato
8helpful
2answers
Calculator lost in nokia 6300
hi... jus connet ur mobile to pc wit nokia pc suite an up date th software r install th applications... so that ur prob might get solved... kindly rate me... thank you..
8helpful
7answers
Master reset code.
i lost my mobile security code of nokia 6300 which serial no is 356960/01/435304/4 i want my code
4helpful
4answers
Missing calculator
I believe your phone is supported by the Nokia Software Updater, use it to either update or reinstall the software and your calculator should return.
Top Nokia Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
