WE Have had to re programme our TV and it has tuned and picked up 50 channels but none of the ITV channels and the picture when on analog or digital keeps freezing intermitently.Can you please help
Are you trying to get over the air channels? IF you are does your TV have the digital tuner on analog? TV went digital and if you have an analog tuner will need either e new TV or converter box.
Are you trying to pick up standard analog channels (the kinds that have a fuzzy gray screen when there's no signal)? Those stopped functioning in 2009 when the nation ended the analog broadcast. You can only get digital channels now, except for a low-power broadcast station here and there. Nowadays for analog, TVs mostly pick up only radio stations.
First check with some of your neighbours to find out if they have the same problem if you are using a communial aerial, if thiers are ok, try re-tuning the TV from "Auto tune" in the set-up menu, this will retune the entire TV & should pick up the missing channels.
There is not a problem with the TV despite it's age this is can be due to your reception of the digital package for BBC. Have you checked through he full listings? sometimes the BBC channel will be at a different number setting because of the transmitter you are receiving. I assume you are using a digital box, you can enter a menu which will give you an indication of the strength & quality of the incoming signal. Do you pick up some of the other BBC channels such as BBC3 or CBBC? It's possible your aerial strength is a bit weak for the digital BBC package & you may need to have that looked at.
The answer to this question can get a little complicated. Lets tackle it in two parts. First the last part; the part about picking up channels as decimals. With analog TV transmission, it took the full television broadcast channel to transmit one standard definition TV program. The newer digital transmission system uses some advanced video compression and audio compression technology to reduce the data needed to transmit the pictures and sound which allows the same bandwidth to deliver either High Definition Television programming or MULTIPLE channels of Standard Definition programs. So in your example above, you use to watch one channel of programming on TV channel 4, but now the TV station can broadcast multiple channels of programming on channel 4, sot they delineate the programs with a decimal point. So 4.1 it the first program on TV channel 4, 4.2 it the second program on TV channel 4..... Well, I hope you get the idea.
Now for the hard part of your question. I believe that before the transition, even with your new digital TV, you were still enjoying the analog broadcasts from your stations. Your VCR picked them up and recorded them and your digital TV could tune them in and you watched as you had always done in the past. After the transition you noticed that your VCR could not record anymore and your digital TV had discovered the digital channels that replace the analog channels. To remedy this situation, your VCR will need the aid of a DTV converter box to tune channels, and you may have to reconfigure the way your TV and VCR are connected. The best resource that I can give your for the reconnecting is the website http://www.fcc.gov/cgb/consumerfacts/converterbox_vcr.html.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Scroll down to the
Normal
0
false
false
false
section about
“Set-up #2: Watch One Channel while Recording a Different Channel”.
