My LG WM 2277HW will not spin during the rinse cycle. I also get an O.F. or O.E. message???? PLease help.
Take off the front kick plate on the bottom and there is a pea trap thats conected to the pump twist it off and see if it is cloged thats what usaully makes it not spin
I have a LG TROMM WM2277HW and last year it started giving me OE errors. I replaced the stator sensor, then the control board. Seemed to be fixed for about 3 months until OE errors started happening again. I always checked the filter cage on the bottom left compartment and nothing has ever been trapped in there. I was at my wits end because buying another machine was not an option. I started with unplugging the machine for 20 minutes to clear the error, I decided to try every cycle and found that the Speed Wash cycle works every time with no error. I set it to any temperature, heavy load and Extra High spin. It does a great job despite being a short 38 minute cycle. This is a Fantastic machine when working properly! This worked for me, good luck!!
I have the same problem, but it leaks from front too..could that be the same indication that it is clogged? How do you take the kick plate off??
