I have had my IBM for around four years maybe more, but its been with my cousin for most of those years. i just got it back but when i turn it on it says IBM than goes straight to a black screen and in the upper left corner is a spot to put in a password. but i cant remember the password i put in, its been years. i now need it for college but i cant even get inside to do work on it, its an IBM thinkpad T22, can you help? i need it.
you need to clean the heatsink of the processor remove it from the motherboard by turning the lock to counter clockwise to 90 degree only all four lock then pull it up gently check for the thermal paste if it is dry you need to add a new thermal paste before you add make sure that you clean the back of the processor or remove the old paste that already dried out, just a small amount you need to apply, then before placing back the heatsink to the processor make sure you already turn the lock to lock position by turning it clockwise 90 degree then make insert it correctly to the four holes in the motherboard then press the lock down slowly to lock one by one,
keep pushing f2 now youll see the page use arrow keys change your boot log f12 now restart it back up on a f12 now it going ask you do you want run windows go there.
Hey, i'm sure you've moved on to another monitor in the past 4 years, but just so you know I had the exact same problem with a cousin's monitor of this type. I've been dinking around and pushed the "auto" button often and held it down a few times. randomly, it started working again! no idea how this problem started, but having at it with the auto button seems to do it!
I had the same problem and changed light control module and now it works. It is above the swing down fuse panel
under the dash on the driver side. Swing the panel down and you can
slide it back a little and it will release. You can get these from a junk year for around $10 or less.
