If you're referring to the small light, just above the fan blade icon on the control panel ... that's the fan speed. It reverts back to LOW each time the unit is manually turned OFF. I that's the one you were referring to, it's nothing to worry about. If you want to raise the fan speed to HIGH, press the fan icon.
Hope this helped to answer your question, Christina. Please let me know.
Q -
Will my dehumidifier work in a cold room ?
A -
A dehumidifier will not operate satisfactory in a room that is
below 65 degrees F. At this temperature it will become necessary to operate the
dehumidifying coil below freezing temperatures in order to reduce the relative humidity to
a reasonable valve. Frost on coils usually will appear.
I would imaging that the humidity is already lower than the dehumidifier could get it down to. that's why it reads "Lo" on the display.
