Compaq Keyboard Logo
Posted on May 04, 2011
How can I type Japanese o keybord? - Compaq Keyboard
Anonymous
Level 1:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Contributor 13 Answers
  • Posted on May 04, 2011
Anonymous
Contributor
Level 1:
Mentor:
Answers
13
Questions
0
Helped
35733
Points
49
Hai ! This is possible : )
Type in Chinese, Japanese, and other character-based languages
To type text on your computer in character-based languages, such as Chinese and Japanese, follow these steps:
[Source: http://windows.microsoft.com/en-us/windows-vista/Type-in-Chinese-Japanese-and-other-character-based-languages]
  1. Add the language as an input language. If you want to use an input method editor (IME), make sure you select it when you add the input language. For more information, see Add an input language.
    You can edit documents in multiple languages by changing the language (the input language) in which you type. Input languages are included with Windows, but you need to add them to your list of languages before you can use them.
    1. Open Regional and Language Options by clicking the Start button how can I type Japanese o keybord? - 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
    2. Click the Keyboards and Languages tab, and then click Change keyboards.
    3. Under Installed services, click Add.
    4. Double-click the language you want to add, double-click the text services you want to add, select the text services options you want to add, and then click OK.
  1. Change your input language to the language you installed. For more information, see Change your input language.
The input language is a setting in Windows that controls the language you use to type information on your computer. Before you can change an input language, you need to add that language to Windows. For more information, see Add an input language.
To change the input language
Click the Input language button on the Language bar, and then click the input language you want to use.
Language bar how can I type Japanese o keybord? - gl_ico.png gl_ico.png Note
If you don't see the Language bar, right-click the taskbar, point to Toolbars, and then click Language bar.
  1. Change your keyboard layout to the desired layout. For more information, see Change your keyboard layout.
You can customize your keyboard for a specific language or format by changing the keyboard layout. The layout controls which characters appear on the screen when you press the keys on your keyboard. Some input languages have several keyboard layouts; others have only one. For example, you can change your keyboard layout from the English QWERTY format to the English Dvorak format. After you change the layout, the characters on your screen might not correspond to the characters on your keyboard keys.
Before you can change the keyboard layout, you must add the input language and keyboard layout that you want to use to Windows. For more information, see Add an input language.
Hide all expcol_imgs.png To change the keyboard layout
  1. On the Language bar, click the Input language button, and then select how can I type Japanese o keybord? - 93d5c617-b1ec-4138-a1ff-973e71de80fe.png
    93d5c617-b1ec-4138-a1ff-973e71de80fe.pngLanguage bar
  2. Click the Keyboard layout button, and then select a keyboard layout.
gl_ico.png Note
If you don't see the Language bar, right-click the taskbar, point to ToolbarsLanguage bar.
expcol_imgs.png To change the keyboard layout on the Welcome screen
On the Welcome screen, click the Keyboard layout button 0c181420-8a93-48b6-82b1-b2dc25fc01b5.png, and then select a keyboard layout.
TIP:
After you are done you can switch between Japanese and English very easily by manually pressing the on screen buttons or using keyboard commands like SHIFT+ALT to switch between Japanese (???) and the Alphabet.
Refresh button
its not on the keybord its on the search bar where you type the website in.
My laptop keybord 1 2 3 bottom don't work,so what can i do?
The only solution is replace the keyboard, [ no user servicable parts] go to www.ebay.com type make and model of laptop, refine search to keyboard.
3answers
The back space key dos not work
Replace the keybord. Or just go to a Electronic's Shop and buy a
USB Keybord.
(you can get a wireless keybord too)
When i type @ its output is " and also i cant find this key \
keybord is set to another defult
you need to set keybord back to US defults if you msg back with the Operating system you are using and type of pc/laptop keybord i can guide u threw it
When I press the shift key and the @ sybol I get " and vice versa, I know there a way of switching this back can anyone help?
dear malch652,
of course.. try to open the controlpanel and find the hardware properties on keyboard lay out. Try to update the keyboard driver and choose yourself (not configured by windows) select the 102 english keyboard lay out or 109keys japanese keyboard lay out (This is for Japanese made). And install it.
Any other way is to chage the regional and language setting on controlpanel and choose your location to match the keyboard input method and lay out according to your need. Don't worry, Windows are user friendly.. don't hesitate to explore, you can add, remove and anything with your keybord lay out.. After you master the keyboard, you can put the back to DEFAULT setting.
GoodLuck!
I connected keybord to my toshiba satellite model ,but some keys like (O,P,....)not writing o or p , its writing numbers
hey man go in control panel-regional and language options-keybords and language-change keybords(and there change u keybord language),If this dosent work try to unistall u keybord drivers and install them again.
My ''P'' key types a ''g'' when struck, and the ''X'' key doesn't...
have u tried another ketyboard?
its possible ur keybords gone 2 keybord heaven buy a new 1
How to type japanese in windows vista
heelo, you will need to install a japanese language software on your computer system before you can be able to type in japanese
MY KEYBAORD IS NOT WORKING RIGHT, WHEN I HIT THE "T" OR "V" IT TYPES IN VT, WHEN I HIT "M" OR "Y" IT TYPES IN MY. WHEN I HIT ENTER IT DELETES AND DOES NOT ENTER
reattche your keybord again to cpu.also ceck in control panel that accessibility go to keybord ten chek there is not any change in default settings.
3answers
LAPTOPS KEYBORD
Uninstall the Belkin software and see if it helps. If not, then you will have to do a soft reinstall of the OS over the curent install with your Packard Bell Windows Cd, or a fresh install. (Make sure you make a back if you are doing a fresh install.
If you have made a restore point earlier, you can try to restore the system to a point before you installed the Belkin router. This way you do not need to do a fresh Windows install. But you will lose any data you stored since the time of that restore point.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
