Hey martyn642002, you can unlock pharmaeu24 Toshiba SE-RO301 to play american DVDs by doing the following
Press the 0 button on your remote control
Press the 3 button on your remote control
Press the 9 button on your remote control
Press the 6 button on your remote control
For more you can visit kamagra Amazon
There are a couple of ways -
One is to get a program called anydvd http://www.slysoft.com/en/anydvd.html this will allow you to play all region dvd's.
Second is to change the region in your computer settings - Start>Control Panel Be aware that windows only allows this so many times before you are locked to whatever you chose last.
This site explains many different solutions to your problem as well as some of the problems involved with doing this.
http://www.gromkov.com/faq/faq2004-0063.html
HI MARTYN,
Toshiba allow cheapo makes to use their brand name sometimes.
So if the player is not a genuine Toshiba then there is likely to be a remote hack on the net some where.
If it is a genuine Toshiba then there wont be a remote hack and you will need somebody like DVD Chips to send you a £20 remote that will hack it.
However - many Toshiba machines will not play NTSC discs at all when first set up.
Check out the Video setup menu and you will see a PAL/NTSC/AUTO option.
Tosh's I've seen are preset to PAL but unlike other players the Tosh will spit out any NTSC discs you try to play- set it to AUTO
Check that setting first just in case that is the only thing stopping it
Here's a Tosh hack to try
1. Press the Open button on your remote control to open the drive tray
2. Press the 2 button on your remote control
3. Press the 4 button on your remote control
4. Press the 0 button on your remote control
5. Press the 3 button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 0 button on your remote control
9. Press the Enter button on your remote control to change the region to 1 for region 1, 2 for region 2, and so on, or 9 for multi-region playback
10. Press the Open button on your remote control to close the drive tray
11. Power off the DVD player
12. Power on the DVD player
If the hack does work make sure the PAL/NTSC setting is on AUTO because R1 disc might still not play
SOURCE: How do I unlock my Toshiba SE-RO301 to play
You can change the region code for your drive a maximum of four times.
To do this Right Click on "Computer" ("My Computer" if using XP), select "Properties" from the drop-down menu, then select "Device Manager (or "Hardware Manager") and click the "+" next to "CD/DVD Drives" and then right click on the description of the drive that you want to change the region code on, select "Properties" and then click on the tab labeled "DVD Region." From the list, select the country associated with the DVDs you want to play or just manually enter "Region 1" (without quotes) in the empty field labeled "New Region." Click "OK" and you're done.
2007 deck TV DVD I bet, and not told , SD4100? DecK? with analog outputs sure.
no country YOU told by you(why?) or better where you bought it? (player)in what country purchased it?
ALL you told was the remote clicker number and was near useless fact nor our failing country told.
you are not i region 1, we see that too .
using Carnac ESP, magic , telepathy
I call it is a deck (TV ,not PC , not battery player) a TV deck. Crystal ball said.
then I look up vast desks with 301 clicker,(over 10)
my wild wild useless guess is this. DECK below for your UNSTATED TV.
TV DECK:
SD4100 secret code is here, most are there. if you learn look here first. the hack is there, and official by maker.
https://www.videohelp.com/dvdhacks/toshi...
the manual is here free too.,
https://www.manualslib.com/manual/203768...
If your deck ,unstated only plays PAL disks that too is a more hUGE problem not region)
PAL regions are here are YOU HERE TOO, not told (all we know is NOT REGION1) and model deck told.
Afghanistan, Algeria, Argentina, Australia, Austria, Bahrain, Bangladesh, Belgium, Brunei, Cameroon, Canary Islands, China, Cyprus, Denmark, Finland, Germany, Ghana, Gibraltar, Greece, Hong Kong, Iceland, India, Indonesia, Iran, Iraq, Ireland, Israel, Italy, Jordan, Kenya, North Korea, Kuwait, Liberia, Luxembourg, Madeira, New Zealand, Nigeria, Norway, Oman, Pakistan, Paraguay (PAL-N), Portugal, Qatar, Saudi Arabia, Sierra Leone, Singapore, South Africa, Spain, Sri Lanka, Sudan, Swaziland, Tanzania, Thailand, Turkey, Uganda, United Arab Emirates, United Kingdom, Uruguay, Yemen, Yugoslavia, Zambia and Zimbabwe.
I am told that most PAL countries DVD decks do both NTSC and PAL decode
so if true, then only region free decks work or need only be switched using the magic codes. in lINK 1 ABOVE.
Cure 2: is rip the DVD to MP4 and play only on a TV deck that does MP4,
handbrake apps does that for free.
My TV allows USB thumb-drive with piles of MP4 as does it allow any exteranal USB HDD to do the same.
cure 3:
https://duckduckgo.com/?q=Megatek+Region...
$40 bucks USA, time to upgrade, no?
NO TV Told , no DECK told , only useless clicker model told. (useless to guess what you own there TV and deck)
d4100 deck
1 Power on the player.(deck) this is not A PC drive nor P1700 portable player is a TV DECK.
2. Open the disk tray.
3. With the remote, enter the numbers 9 8 7 9 and
then press 0 (for region 0, or multi-region). A prompt
at the upper right hand corner of the start screen should tell you that the player has been set to region 0.
4. Close the disk tray.
5. Power off the player and then power it back on.
Good luck!!!
cure 4: buy a DVD TV deck from USA EBAY (HDMI or composite video as the case may be)
ship it to your unstated country and bingo solved. region 1 solved.
vast cheap decks sold use there. endless.
not bad , 4 cures now
need more ask and tell what TV this is, and deck model first. back of TV sticker model and same place on the deck not told.
cure #5https://www.videohelp.com/dvdhacks
see those vast decks, buy one and use its clicker to go region free code 0
