Hello Brianna_C_lo, this can be an array of things but it all depends on the model # and TW # located on the back of the TV. Please provide me this information and I will let you know either the code, if you need a FW update, or if there is a problem with the sensor. You can post back to me here or send me a direct email with the information to [email protected].
11866, 10054, 10030, 10706, 11990, 11963, 11913, 11904, 11525, 11365, 11198, 10802, 10230, 10187, 10186, 10179, 10096, 10036, 10028, 10024, 10020
Philips TV codes with Comcast Universal remote control are:-
10054, 10037, 10690, 11483
1. Turn on the TV
NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2.
2. Press and hold SETuntil the Red Light blinks twice, then release SET.
3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first.
4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice
NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code
OK.
11864, 10054, 10030, 10171, 10020, 10028, 10065, 10096, 11314, 11665, 11963
Turn on the TV
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
Ok.
10154, 10451, 10236, 10463, 10180, 10178, 10171, 11963, 11928, 11913, 11911, 11909, 11905, 11665, 10282, 10280 10270, 10183, 10181, 10179 10177, 10038, 10019
You have to check with each code, until you find which code sets for your TV
programming TVcontrol
The Comcast Digital Adapter remote control is pre-programmed at the factory to operate the Digital Adapter. The Comcast Digital Adapter remote also contains a universal TV library to allow you to control the Power and Volume of your TV.
1. Turn on the TV
If your brand of TV does not respond to the remote control after trying all of the codes listed, or if your brand is not listed at all, try searching for your code.
1. Turn on your TV.
3. Enter in 9 - 9 - 1. The Red Light will blink twice.
4. While pointing the remote control at the TV and press and release the CH + key until the TV turns off. (Note: You may need to press [CH+] numerous times).
NOTE: In the search mode, the remote control will send IR codes from its library to the TV.
5. Press SETonce to lock in the code. The Red Light will blink twice.
OK.
10812, 10060, 10702, 10178, 10030, 11959, 11632, 11575, 11060, 10814, 10766, 10587, 10482, 10427, 10408, 10329, 10217, 10056, 10032, 10019
1. Turn on the TV
6. For future reference, write your code below.
