Dell Inspiron Mini 1012 Netbook (IM1012799OBK) Logo
A
Anonymous Posted on May 06, 2011
7 beep error message for dell inspiron mini 1018
Anonymous
Level 2:
New Friend:
  • Expert 72 Answers
  • Posted on May 06, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
72
Questions
0
Helped
37114
Points
198
For the Dell Inspiron Mini 1012 Netbook, 7 beeps indicates bad memory (system RAM). The memory will need to be replaced.
The RAM can be replaced using a small Phillips screwdriver and removing the back-plate on the bottom of the laptop. When you see the memory (sticks around 3 inches long), pull those out and put new ones in. Make sure it's the correct DDR2 memory.
Need hdd password dell inspiron mini
I NEED AN HDD PASSWORD FOR MY DELL INSPIRON MINI 1018 MY SERVICE TAG CODE IS 2V2J2Q1
My laptop has a I/O error and now i cant get into my laptop
this is serious and denotes internal damage/corruption
2answers
Inspiron mini 1018 blank screen with light behind, loud beeps, strange smell
I have green screen solution where now it changed to whole black screen with some red line and produce a sound like TV Signal..I don't know everthings about repair my netbook..What should i do?
1helpful
How do i restore factory settings on my dell inspiron mini 1018
This is quite easy to do, when your turn on your computer you need to hit a hotkey over and over again. The hotkey is different for each type of laptop but the common ones are f11, f1, f2, alt+0 and f12.
Once you reach the recovery screen you just need to follow the on screen prompts and you're all set
WARNING: Doing this will mean that you will lose all your personal data and installed programs that are on the computer.
I cant turn on mya dell inspiron mini 1018. screen is black and 8 signal, tu tu tu tu... all the time. what can I du? what problem is that? plesa help me...
If the system is giving you eight beeps, its an error code for display failure. You would have to get in touch with service tech, to either reseat the display cable or get the display replaced . I would suggest call Dell technical support if the system is in warrnaty.
In case you want to do it yourself the following is the link of the service manual
Service manual
Thanks for using fixya
Proton
2answers
I have a dell inspiron mini 1018. while travelling i made the mistake of placing it in the heavy luggage. when i arrived it wouldnt open, just made 7 beeps. next day it opens for a few minuets then closes....
According to Dell the 7 beep codes indicate " CPU Cache test failure" which means your 1018 has a " CPU Failure". This can be caused by a defective CPU or the motherboard. I'm not positive but I believe the CPU is soldered to the motherboard hence the motherboard would have to be replaced.
WEBCAM DRIVER FOR DELL INSPIRON 1018 MINI
I need the Wifi driver for my Dell 1018 Vostro laptop win 7. i am not able to get it .. please help me out and mail to me link or driver on
[email protected]
My Dell inspiron mini 10 is just over 1 year old not used very much at all, last week for no reason there is no display on the screen, I tried to reboot on battery power and ac no luck. Thanks Frank.
There are 3 mini 10 models sold by Dell. The Inspiron 1010 (Mini 10), Insprion 1012 (Mini 10) and the Insprion 1018 (Mini 10v). Depending on which model you have, you can try to connect an external monitor and see if you get a display. The 1012 and the 1018 have a 15 pin VGA plug on the left side of the laptop and the 1010 has an HDMI jack for video. If you get a display then your LCD display is bad and needs to be replaced.
No drivers for inspiron mini 1018
Dell Inspirion Mini 10(1018) Windows 7 x86 drivers software -Download Here.
Regards
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
