Go to MENU, SETUP,
There you can reset to factory settings. After you set the clock and date, it will ask to scan for all active channels and it will block out the channels it does not find a signal for. Let it complete this task (20 minutes). It asks you for the type of signal but just leave the STD setting for both options before starting the channel finding routine.
When complete, go to channel 10 to see what show is on (low def version). then click down to channel 2 and then push the channel down button several times again to try and find the HD version of that show. (HD channels are high-number channels that are easiest to get to by scrolling below channel 2. Most will have a hyphan in the channel name (e.g. 93-2; 94-1, 94-2, ...).
If your TV goes directly to a 2-digit channel, they you do not have an HD tuner in your set. I doubt that is true so I think you will find what you need.
Let me know if it doesn't work.
