Question about ViewSonic N3250W Television
I have an N3250W-L it has the screen White, normal sound.May be one blown fuse in the "T CON" Board?
    Genius:
  • 1,156 Answers
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this will help out in solving the problem......
Posted on May 06, 2011
6ya staff
SOURCE:
Black screen, but sound
maybe it is the panel eeprom,if the panel inverter is good which should be treated with experts
Jan 14, 2013 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Sharp Lc-26sb24u white screen with sound
You will get a white screen when you unplug the t-con from the main board. Doing so removes power to the LCD panel. Verify that all of your voltages from the power supply are correct. If they are, I'd look at the t-con board. It sounds like there is a problem with the t-con that is pulling down the main board.
May 11, 2012 | Sharp LC Televison & Video
My lcd monitor produces only white screen...what should i do???
If you olny getting white glowing screen, it can be the connector to the T-CON board on the LCD panel came off or it has blown fuse on the T-CON board, or the logic board is not sending the 5 or12vdc to the T-CON board.
Please read below:
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 02, 2010 | AOC 193FW LCD Monitor
The screen is white.power is on, simply no picture, white screen
Hi:
This could be cause by one to two areas of the unit, first the T-CON board may be bad and second the main system board has failed. The t-con is used to produce the picture on the screen it gets its data from the digital board or system control board. The screen is white because the inverter board is working to light up the lamps.
Aug 17, 2010 | Samsung LN-S2651D 26 in. LCD Television
Screen turned white, only sound to hear
It tuns white because he T-CON board is not working due to blown fuse on the board or it is no getting the voltage from the main board, you can check for voltage at the T-CON fuse, you need to find out if the T-CON board is part of the LCD panel assembly or it is its own assembly, if it is part of the panel, thne it will not be worth fixing since the new screen will be needed.
If you are going to DIY and have proper tools, knowledge of electronics and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Parts: www.shopjimmy.com
Jul 12, 2010 | Daewoo DSL19T2WCD 19 in. LCD TV TV/DVD...
Cl772b sylvania (model 780) go to white screen after 10 sec power on. No visual signal of damage.
You get white screen glow when the T-CON board on the LCD panel does not receive the +5dvc feeding it or it has blown fuse on the T-CON board, see picture of the T-CON board and the fuse here:
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Look at the logic board to see if the ribbon cable may have come off the LCD panel or the logic board, also look to see if you can see any bad caps (leaking/bulging top).
http://www.badcaps.net
May 31, 2010 | Sylvania CL772B 17" Flat Panel LCD Monitor
Samsung syncmaster 731bf screen stays white!
It sounds like the T-CON board (part of the LCD panel) is not getting the +5vdc from the logic bd. Check the ribbon cable between the panel and the logic bd. first, then check to see if it has blown fuse on the T-CON bd.
May 30, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
Hello my n71s has been lit white screen and no menu buttons work I can turn off. I tested on other computers and with various resolutions even in safe mode help
When you have white glow and no pictures, then more likely the the LCD T-CON board (part of LCD panel assembly) is not getting 5vdc feeding it, it can be blown fuse on the T-CON board or the logic board is not feeding the 5vdc to the T-CON board.
You need to check the power supply and the logic board first for bad caps (leaking/bulging top).
Please see my pictures here:
May 15, 2010 | Hyundai Electronics ImageQuest N71S 17"...
N3250W: Sound w/ no picture.
you may have a bad inverter board. check for 24volts to the board.
Dec 30, 2009 | ViewSonic N3250W Television
I am getting a white screen (no picture) on a polaroid LCD
People any lcd tv with a white screen cause by the T-con board if you have some experiences you can check with a multimeter the (smd) fuse on the T-con board it is right in de middel on top in the back of the tv. you might have to move some of the boards to get to it. if the fuse is broken replace it with another smd fuse otherwise relace the t-con.
Jun 28, 2009 | Polaroid FLM-1911 19 in. LCD Television
Televison & Video Logo
66 people viewed this question
Top ViewSonic Televison & Video Experts
lubomir73
Level 1 Expert
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
