SOURCE: sammsung s4253 plasma tv audio garbled on digital channels
I had the same problem with my S4253 using Directv. I then turned off the Dolby Digital on the sound settings on the Directv satellite box. Problem went away.
SOURCE: is my LG 32lz50 tv hd and digital
Your tv is HDTV ready but unfortunatly it only has a NTSC tuner which is analog, you will need a set top box to recieve OTA over the air digital, if you have cable sattilite or an HD dvd player you can display HD. You only need the set top box if you use an anttenna.
Let me know if I can assist further and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: my philips lcd digital tv says I am recieveing
First verify that the direct TV satellite box is set to receive and display digital stations. If you old set on the sat was analog, the box may not have been reset. You may have to contact you satellite provider. Next you will have to go to the TV menu and auto program/scan in the stations. This should pick up all the stations.
SOURCE: Receiving the sound but no picture on digital TV channels
If you are trying to watch HD TV through the tv and you are only getting sound, it is most likely because you would need an High Definition cable box. Hope it helps
