1997 Jeep Grand Cherokee Logo
Posted on May 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need a diagram for a belt tensioner/idler pulley\r\n 97 jeep grand cherokee laredo 5.2liter
Lloyd Carter
Level 2:
Habit-Forming:
  • Expert 153 Answers
  • Posted on May 07, 2011
Lloyd Carter
Expert
Level 2:
Habit-Forming:
Answers
153
Questions
Helped
43637
Points
439
1998 Jeep Grand Cherokee 5.2 Liter And 5.9 Liter Serpentine Belt Routingneed a diagram for a belt tensioner/idler - 91350183.gif try this link http://autorepair.about.com/library/pictures/illustrations/bl750a-lib.htm
2000 jeep keeps throwing the belt hafe way off
That has the big serpentine belt and a tensioner. Check the tensioner and the idler pulley.
Idler pulley burning belt rubber. idler bad?
yes, if it is frozen up the belt will squeal and burn up ! you can go to any auto parts store and tell them you need a idler pulley for your vehicle. good-day !
I need a belt diagram for a 1991 jeep cherokee laredo
Thank you for the inquiry.
Visually inspect the fan shroud, Top radiator brackets, or power steering pump for decal.
If unable to locate your can logic it out by just matching the inside grooves with the grooves and the flat side with the flat outside pulleys. It will make make sense when you carefully look at it. There is only a few pulleys and a couple of idlers to thread and frap it around.
The tension for the belt is adjusted with the altenator.
Can't find serpentine belt tensioner on 97 Jeep Grand Cherokee
right, for the 4 liter,
  1. Loosen the rear power steering pump mounting bolts using a ratchet and 13mm socket or a 13mm box wrench.
  2. Loosen the pump upper pivot bolt, lower locknut and the pump adjusting bolt using a ratchet and 13mm socket or a 13mm box wrench.
For the V8
  1. Attach a socket or wrench to the pulley mounting bolt on the automatic tensioner and rotate the tensioner assembly clockwise until the tension has been removed from the belt.
  2. Remove the belt from the idler pulley first and then from the vehicle.
1helpful
Need serpentine belt diagram for 1994 Jeep grand cherokee v8. 5.2 liter. Don't have acess to vehicle to go to store or library.
Starting at a/c compressor working clockwise: Over a/c, over p/s pump, backside of belt over water pump,, down around crank pulley, up over idler/tensioner, over alt, under idler and back to a/c.
Diagram 2004 jeep grande cherokee serpentine belt
For the 4.7L: Looking at the Pulley straight on and Starting at the top Left (AC) and going right (clockwise):
Over the AC Pulley.
Under the Water Pump Pulley.
Over the Generator Pulley
To the right side of the Power Steering Pulley.
Under the Crankshaft Pulley.
To right side and up and over the Lower Idler Pulley.
To under and around the left side of the Tensioner Pulley,
Connecting to the Left Side and Up and over the AC.
2helpful
Serpentine belt diagram for 2000 jeep grand cherokee 6 cylinder
Around the outside of power steering pulley,under idler,over a/c comp,around alternator,over fan pulley, around crank pulley, over water pump. The backside of the belt contacts the idler, fan and water pump.
2answers
Drive belt came off pulley loose on 2007 jeep grand laredo
The center pully is the IDLER PULLEY.
It is also referred to as the TENSIONER.
It has a coiled spring that creates the belt tension. Replace it ($15) (and the belt) ($8).
Hope this helps!
2helpful
2000 jeep grand cherokee 4.0 liter engine timing belt replacement
If you have the same pulley arrangement that most 4.0 engines have that pulley is an idler not a tensioner. Your power steering pump has a pivot bolt, and a slide under the pump. You adjust belt tension using the pump.
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
