My wae18060au bosch washing machine is stuck on rinse, has happened before a technician came out and showed me how to fix it but i cant remember he turned the dial and held down a button seemed extremely easy!
your are in big trouble the bearings ore gone and seems like you have used it while the bearings were gone and the shaft could be damaged im afraid its a new machine for you it would be very expensive to fix
Bosch Exxcel 1400 washing machine
This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE
question.
And don't forget to like us on
facebook
Bosch WFL 2872 washing machine that is leaking
This video will show you how to change the pump washing
machine
question.
facebook or it could be the seal
Bosch WFX145SGB
machine
question.
facebook
To change the seal the easiest way is to take the front of the appliance off.
Remove the kick plate at bottom and you will see some screws holding the front panel on remove these
Then open door and remove the screws holding the door lock on and unlip the seal by releasing the clamp on the front.
The front should now lift off, if it doesnt then pull out the soap drawer and behind that at the bottom of the drawer is a screw holding the front on remove this then push the front panel down then it will lift off
You can now take the clamp holding the seal to the tub off.
Fit the new seal, fit the clamp to the seal and tub.
From here, rebuilding is the reverse of the strip down.
