Dell Inspiron 1525 Notebook Logo
Posted on May 08, 2011
My mouse key keep moving auto... and automatically keep on clicking on different programs... i guess i need to lock my laptop mouse for this but don't know how to lock my mouse in dell inspiron 1525
A
Anonymous
In the Control Panel, select Mouse and the Pointer Options tab. Uncheck "Enhance pointer precision" and the problem may go away.
The cursor will not move I think I have locked the touch pad by mistake
Use a temporary external USB mouse, Click Start button from your laptop. Type "mouse" in Search Program & Files, click mouse under control panel. click Hardware tab,click properties, click change settings, click driver tab, check if the device is enable or click update diver or rollback driver if necessary.
Acer Laptop Help
To get started with this product, complete the following steps.
Turn the laptop on by pressing the Power button located above the keyboard.
Locate the touchpad.
You use the touchpad much like you would use a mouse.
The touchpad controls your cursor.
It responds as you move your finger across its surface.
Move your finger across the touchpad to move the cursor.
Locate the bar below the touchpad.
This bar may be used for selecting and has left and right-click functions that you can use a mouse.
Clicking on the right end of the bar has the same effect as right-clicking with a mouse.
Clicking on the left end of the bar has the same effect as left-clicking with a mouse.
Tapping the touchpad is the same as clicking the left end of the bar.
Use the keyboard like you would use a desktop keyboard.
The only difference is that the keyboard of an Acer laptop is smaller than a regular laptop keyboard.
Click on the Windows icon in the lower left side of the screen to access programs.
Make sure your wireless switch is turned on, if you want to access the Internet.
Then locate a wireless network.
Windows may automatically detect and display a list of available networks.
If that happens, you only have to select the network you wish to access.
If it is not your network, you may need a password if it is security-enabled.
If Windows does not automatically detect a network, open Internet Explorer, and follow the on-screen instructions to connect to a wireless network.
Acer user guides and manuals
http://safemanuals.com/brand-user-guide-instructions-owner-manual/ACER
To adjust rotating display of laptop ,taskbar with all icons moves on different(bottom to top)
Step 1:
Has your Windows taskbar suddenly moved to the side of your desktop screen or even to the top? This can be very disruptive to your daily computing, which may mean a loss of productivity at work. Your taskbar could have moved because of a glitch in programming or an inadvertent mouse click while you were focused on something else. The latter is more common and is usually the result of an unlocked taskbar.
Older Windows Operating Systems Windows 98, Windows ME, Windows XP and Windows Vista all utilize similar solutions for this problem. For the quickest route to returning the taskbar to the bottom of the screen, first place your mouse pointer over empty space on your taskbar (space not occupied by an icon or a button indicating an open program) and right-click. Look near the bottom of the menu that appears for the "Lock the Taskbar" listing, and make sure there is no check mark next to the listing. If there is a check mark, it means the taskbar is locked and cannot be moved, so click on the listing to deselect (and unlock) it. With your mouse pointer again over an empty space on the taskbar, click and hold the left mouse button and then move the mouse pointer to the bottom of the screen. When you release the left mouse button, your taskbar should have moved. As long as the taskbar is unlocked, you can also vary its height. Hold the mouse pointer over the upper edge of the taskbar until it becomes a double arrow (pointing up and down). Then click and hold while you drag the upper edge of the taskbar to the you desire. Once you have the taskbar where you want it, remember to lock it again by selecting the listing on the right-click taskbar menu.
Another option is to visit the Microsoft Windows website and download and run an automatic "Fix it" program, which should take care of programming issues. Windows 7
There are three options for moving the taskbar in the Windows 7 operating system. The first option involves right-clicking on an empty space in the taskbar and then navigating to the "Properties" menu (look near the center of the menu) to set the location of your taskbar on your screen. This menu also allows you to change or establish a number of other default settings relating to your Start menu and taskbar. The second option is exactly the same as the first process given for the Windows operating systems previously mentioned. And again, to prevent the format you have established from changing, lock the taskbar by right-clicking on an empty space of the taskbar and selecting "Lock the Taskbar" from the menu. The third option is a bit more involved and requires downloading registry files (files ending in ".reg"), saving them to your desktop and then double-clicking on them to merge them with your operating system. The files can be deleted after use.
Microsoft online support
http://support.microsoft.com/kb/253679
2answers
My cursor won't move
Yes, you should buy a new mouse, please also say what is the warranty of your current mouse?
Release the scroll key
    • 1 Open and power on the laptop.
    • 2 Wait for the laptop to fully boot.
    • 3 Locate the "Scroll" button at the top-left of the keyboard. It is under the volume panel and between the "F12" and "Pause" keys.
    • 4 Press the "Scroll" button.
    • 5 Test it by opening a spreadsheet and using the arrow keys to move around on it. You can open your Microsoft Excel program or create a spreadsheet online by using Google Docs (free online productivity software). The "Scroll Lock" function will keep the current cell selected while the screen moves.
    • 6 Press "Scroll Lock" again to turn it off.
Mouse on computer stopped working have tried 3 different ones and also different ports also did hit reset on them can't get to any programs or do a system restore because he has no pointer to navigate what...
To go system restore, click the windows button, porgrams, accessories, system tools, system restore. Also you can turn on mouse keys by press shift continually, use keyboard to navigate to setting. When in settings use tab the get to the mouse tab, tick actuvate mouse key tab and save setting by pressing ok or apply. Turn on number lock to use... 8-up, 2-down, 4-left and 6-right. Goodluck!
How do I turn off the automatic scrolling feature? a mini scroll bar appears on the page and my attempt to move the cursor instead moves the page up and down. Most annoying. I've tried the scroll button...
what OS, XP? operating system? is it?
using only one mouse? the built in mouse pad or it and a plugin mouse at USB port? or external wireless mouse.
we cant see what you have there, nor what are are using now.
if the PC is not infected.
click control panel, the click mouse icon there, bingo change mouse actions.
or reload the HP mouse driver.
4helpful
Internal mouse will not move and lights are red/orange
this might be a problem with the mouse lock..
check ur mouse lock button just above the mouse pad.
if its locked, unlock it & try again.
if its not locked, then go to device manager via right clicking My Computer, properties
select mouse device & expand the tab
uninstall the mouse, dont worry it can be done without mouse.
now press the windows key from keyboard, and restart ur system via pressing Start key, +u, +r for windows Xp & for Windows Vista, press ALT+F4 then select restart.
After ur machine boots up, it will automatically detect the mouse & reinstall the required drivers. its done
if u like my post, pls rate me.. i really need some good ratings..
Thanks
4helpful
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
4helpful
2answers
Turn off scroll button
hold down the fn key and press the scroll button.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
