Toastmaster 1148X FastBake Bread Maker Logo
Posted on May 08, 2011
Error code he 3 - Toastmaster 1148X FastBake Bread Maker
Cannot connect to netflix error message code is ui-800-3
Netflix help center has it listed ...
"If you experience the error code UI-800-3 (205040), it typically points to information stored on your device that needs to be refreshed. Follow the troubleshooting steps for your device below to resolve the issue."
https://help.netflix.com/en/node/46037
tip
System Beep Code Error
Beep Code Manual, Better Than Gold Techies, American Megatrends Int. & Phoenix
BIOS Beep Codes
When a computer is first turned on, or rebooted, its BIOS performs a power-on self test (POST) to test the system's hardware, checking to make sure that all of the system's hardware components are working properly. Under normal circumstances, the POST will display an error message; however, if the BIOS detects an error before it can access the video card, or if there is a problem with the video card, it will produce a series of beeps, and the pattern of the beeps indicates what kind of problem the BIOS has detected.
Because there are many brands of BIOS, there are no standard beep codes for every BIOS.
The two most-used brands are AMI (American Megatrends International) and Phoenix.
Below are listed the beep codes for AMI systems, and here are the beep codes for Phoenix systems.
AMI Beep Codes
Beep Code Meaning
1 beep DRAM refresh failure. There is a problem in the system memory or the motherboard.
2 beeps Memory parity error. The parity circuit is not working properly.
3 beeps Base 64K RAM failure. There is a problem with the first 64K of system memory.
4 beeps System timer not operational. There is problem with the timer(s) that control functions on the motherboard.
5 beeps Processor failure. The system CPU has failed.
6 beeps Gate A20/keyboard controller failure. The keyboard IC controller has failed, preventing gate A20 from switching the processor to protect mode.
7 beeps Virtual mode exception error.
8 beeps Video memory error. The BIOS cannot write to the frame buffer memory on the video card.
9 beeps ROM checksum error. The BIOS ROM chip on the motherboard is likely faulty.
10 beeps CMOS checksum error. Something on the motherboard is causing an error when trying to interact with the CMOS.
11 beeps Bad cache memory. An error in the level 2 cache memory.
1 long beep, 2 short Failure in the video system.
1 long beep, 3 short A failure has been detected in memory above 64K.
1 long beep, 8 short Display test failure.
Continuous beeping A problem with the memory or video.
BIOS Beep Codes
Phoenix Beep Codes
Phoenix uses sequences of beeps to indicate problems. The "-" between each number below indicates a pause between each beep sequence. For example, 1-2-3 indicates one beep, followed by a pause and two beeps, followed by a pause and three beeps. Phoenix version before 4.x use 3-beep codes, while Phoenix versions starting with 4.x use 4-beep codes. Click here for AMI BIOS beep codes.
4-Beep Codes
Beep Code Meaning
1-1-1-3 Faulty CPU/motherboard. Verify real mode.
1-1-2-1 Faulty CPU/motherboard.
1-1-2-3 Faulty motherboard or one of its components.
1-1-3-1 Faulty motherboard or one of its components. Initialize chipset registers with initial POST values.
1-1-3-2 Faulty motherboard or one of its components.
1-1-3-3 Faulty motherboard or one of its components. Initialize CPU registers.
1-1-3-2
1-1-3-3
1-1-3-4 Failure in the first 64K of memory.
1-1-4-1 Level 2 cache error.
1-1-4-3 I/O port error.
1-2-1-1 Power management error.
1-2-1-2
1-2-1-3 Faulty motherboard or one of its components.
1-2-2-1 Keyboard controller failure.
1-2-2-3 BIOS ROM error.
1-2-3-1 System timer error.
1-2-3-3 DMA error.
1-2-4-1 IRQ controller error.
1-3-1-1 DRAM refresh error.
1-3-1-3 A20 gate failure.
1-3-2-1 Faulty motherboard or one of its components.
1-3-3-1 Extended memory error.
1-3-3-3
1-3-4-1
1-3-4-3 Error in first 1MB of system memory.
1-4-1-3
1-4-2-4 CPU error.
1-4-3-1
2-1-4-1 BIOS ROM shadow error.
1-4-3-2
1-4-3-3 Level 2 cache error.
1-4-4-1
1-4-4-2
2-1-1-1 Faulty motherboard or one of its components.
2-1-1-3
2-1-2-1 IRQ failure.
2-1-2-3 BIOS ROM error.
2-1-2-4
2-1-3-2 I/O port failure.
2-1-3-1
2-1-3-3 Video system failure.
2-1-1-3
2-1-2-4 I/O port failure.
2-1-4-3
2-2-1-1 Video card failure.
2-2-1-3
2-2-2-1
2-2-2-3 Keyboard controller failure.
2-2-3-1 IRQ error.
2-2-4-1 Error in first 1MB of system memory.
2-3-1-1
2-3-3-3 Extended memory failure.
2-3-2-1 Faulty motherboard or one of its components.
2-3-2-3
2-3-3-1 Level 2 cache error.
2-3-4-1
2-3-4-3 Motherboard or video card failure.
2-3-4-1
2-3-4-3
2-4-1-1 Motherboard or video card failure.
2-4-1-3 Faulty motherboard or one of its components.
2-4-2-1 RTC error.
2-4-2-3 Keyboard controller error.
2-4-4-1 IRQ error.
3-1-1-1
3-1-1-3
3-1-2-1
3-1-2-3 I/O port error.
3-1-3-1
3-1-3-3 Faulty motherboard or one of its components.
3-1-4-1
3-2-1-1
3-2-1-2 Floppy drive or hard drive failure.
3-2-1-3 Faulty motherboard or one of its components.
3-2-2-1 Keyboard controller error.
3-2-2-3
3-2-3-1
3-2-4-1 Faulty motherboard or one of its components.
3-2-4-3 IRQ error.
3-3-1-1 RTC error.
3-3-1-3 Key lock error.
3-3-3-3 Faulty motherboard or one of its components.
3-3-3-3
3-3-4-1
3-3-4-3
3-4-1-1
3-4-1-3
3-4-2-1
3-4-2-3
3-4-3-1
3-4-4-1
3-4-4-4 Faulty motherboard or one of its components.
4-1-1-1 Floppy drive or hard drive failure.
4-2-1-1
4-2-1-3
4-2-2-1 IRQ failure.
4-2-2-3
4-2-3-1
4-2-3-3
4-2-4-1 Faulty motherboard or one of its components.
4-2-4-3 Keyboard controller error.
4-3-1-3
4-3-1-4
4-3-2-1
4-3-2-2
4-3-3-1
4-3-4-1
4-3-4-3 Faulty motherboard or one of its components.
4-3-3-2
4-3-3-4 IRQ failure.
4-3-3-3
4-3-4-2 Floppy drive or hard drive failure.
3-Beep Codes
Beep Code Meaning
1-1-2 Faulty CPU/motherboard.
1-1-3 Faulty motherboard/CMOS read-write failure.
1-1-4 Faulty BIOS/BIOS ROM checksum error.
1-2-1 System timer not operational. There is a problem with the timer(s) that control functions on the motherboard.
1-2-2
1-2-3 Faulty motherboard/DMA failure.
1-3-1 Memory refresh failure.
1-3-2
1-3-3
1-4-1 Address line failure.
1-4-2 Parity RAM failure.
1-4-3 Timer failure.
1-4-4 NMI port failure.
2-_-_ Any combination of beeps after 2 indicates a failure in the first 64K of memory.
3-1-1 Master DMA failure.
3-1-2 Slave DMA failure.
3-1-3
3-1-4 Interrupt controller failure.
3-2-4 Keyboard controller failure.
3-3-1
3-3-2 CMOS error.
3-3-4 Video card failure.
3-4-1 Video card failure.
4-2-1 Timer failure.
4-2-2 CMOS shutdown failure.
4-2-3 Gate A20 failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure.
4-3-3 Timer failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port failure.
4-4-2 Parallel port failure.
4-4-3 Math coprocessor.
on Feb 02, 2010 • Computers & Internet
tip
Beep Code Manual
(I'm Computer Technician, I use these codes to trouble shoot hardware issues at my job. Enjoy.)
BIOS Beep Codes
When a computer is first turned on, or rebooted, it's BIOS performs a power-on self test (POST) to test the system's hardware, checking to make sure that all of the system's hardware components are working properly. Under normal circumstances, the POST will display an error message; however, if the BIOS detects an error before it can access the video card, it will produce a series of beeps, and the pattern of the beeps indicates what kind of problem the BIOS has detected. Because there are many brands of BIOS, there are no standard beep codes for every BIOS.
AMI Beep Codes
Beep Code Meaning
1. beep DRAM refresh failure. There is a problem in the system memory or the motherboard.
2. beeps Memory parity error. The parity circuit is not working properly.
3. beeps Base 64K RAM failure. There is a problem with the first 64K of system memory.
4. beeps system timer not operational. There is problem with the timer(s) that control functions on the motherboard.
5. beeps Processor failure. The system CPU has failed.
6. beeps Gate A20/keyboard controller failure. The keyboard IC controller has failed, preventing gate A20 from switching the processor to protect mode.
7. beeps Virtual mode exception error.
8. beeps Video memory error. The BIOS cannot write to the frame buffer memory on the video card.
9. beeps ROM checksum error. The BIOS ROM chip on the motherboard is likely faulty.
10. beeps CMOS checksum error. Something on the motherboard is causing an error when trying to interact with the CMOS.
11. beeps Bad cache memory. An error in the level 2 cache memory.
1 long beep, 3 short A failure in the video system.
1 long beep, 8 short display test failure.
BIOS Beep Codes
Phoenix Beep Codes
For example, 1-2-3 indicates one beep, followed by a pause and three beeps. Phoenix version before 4.x use 3-beep codes, while Phoenix versions starting with 4.x use 4-beep codes.
4-Beep Codes
Beep Code Meaning
1-1-3-2
1-1-3-3
1-2-1-2
1-2-3-3 DMA error.
1-3-3-3
1-3-4-1
1-4-1-3
1-4-2-4 CPU error.
1-4-3-1
1-4-3-2
1-4-4-1
1-4-4-2
2-1-1-3
2-1-2-4
2-1-3-1
2-1-1-3
2-1-4-3
2-2-1-3
2-2-2-1
2-2-3-1 IRQ error.
2-3-1-1
2-3-2-3
2-3-4-1
2-3-4-1
2-3-4-3
2-4-2-1 RTC error.
2-4-4-1 IRQ error.
3-1-1-1
3-1-1-3
3-1-2-1
3-1-3-1
3-1-4-1
3-2-1-1
3-2-2-3
3-2-3-1
3-2-4-3 IRQ error.
3-3-1-1 RTC error.
3-3-3-3
3-3-4-1
3-3-4-3
3-4-1-1
3-4-1-3
3-4-2-1
3-4-2-3
3-4-3-1
3-4-4-1
4-2-1-1
4-2-1-3
4-2-2-3
4-2-3-1
4-2-3-3
4-3-1-3
4-3-1-4
4-3-2-1
4-3-2-2
4-3-3-1
4-3-4-1
4-3-3-2
4-3-3-3
3-Beep Codes
Beep Code Meaning
1-2-2
1-3-2
1-3-3
3-1-3
3-3-1
3-3-2 CMOS error.
on Dec 31, 2009 • Computers & Internet
How can i fix error 0001
Xbox-experts.com - Error code 3 RLOD E01 / 0001
https://xbox-experts.com/errorcode/E01/0001/
General info on Error code : 3 Red Lights E01 0001 and how to fix it!. Short circuit in the console/faulty PSU. E-Code / Secondary Error code‎: ‎E01 (No ...
Binary/Hex‎: ‎00000001 / 0x01 -> 1
Primary Error code‎: ‎3 RLOD
My computer retain this error and close application error code 3
I am also getting error code 3. I am able to transfer files using the exe. but running it from the scheduler/console I get:
permission denied
error code 3
error message from server permission denied.
why would I get that from the console and not from the ex
for more help visit CBR Tech Solutions
AIT-3 Tape Ejects when they put in MSSQL 4027
You will not find the list of the error codes on the internet. I know that Error Code: 0x81 is a "Reel" problem as I was just told by Sony Support. You should call them, have you serial number at hand when you do so. Check http://sony.storagesupport.com/ for a Telephone contact number.
Good luck, Bruno
Service 900 error message
900 Error Code service check
1 Printer POR
Turn the printer off and on several times. If Error Code 900 continues
to display, go to step 2.
2 System board
Make sure the system board is properly seated in connector J7 on
the interconnect board.
Turn the machine off and on several times, waiting a few minutes
between power on and power off.
If Error Code 900 continues to display, go to step 3.
3 Factory defaults
Restore factory defaults. See “Restore EP Factory Defaults” on
page 3-18. This resets the non-critical areas of the user NVRAM. If
Error Code 900 continues to display, go to step 4.
4 Sub error codes
With Error Code 900 displayed, press Select and Return. Record the
complete list of Sub Error Codes on the display. Check the “Base
printer sub error codes” on page 2-6. If none of the Sub Error
Codes are listed, then call your next level of support.
From page 2-41 of IBM's service Guide
9helpful
3answers
CD disk error
ok error code 1, look for this error code on your owners manual, toyota cd players give 3 error codes, this mean error code 1, error code 2, and error code 3, they all have different meaning please check owners manuel to see what does error 1 mean i will try looking for you
Code errors on kodak easyshare esp 3
error code 3501 means the front access door is open on the printer. Error code 3502 means the paper tray is empty. The error code 3602 means the print job did not finish printing.
for more hrlp visit CBR Tech Solutions
49helpful
4answers
Error code 1/-3/1090 Doc #5305
Uninstall Nero 7 and reinstall
=^_^=
Top Toastmaster Kitchen Appliances - Others Experts
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
