Gateway 7320GZ Notebook Logo
Posted on Aug 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem with the screem
I have a gateway 7320GZ lap top, the problem is that whem i turn it on the lcd screem is dark, I´ve conected the lt to a external monitor and image is normal
pls if you have any idea how can i fix this problem i will apreciate your help
Thanks in advance
Pedro
Toby Lee
Level 3:
  • Master 409 Answers
  • Posted on Jul 28, 2009
Toby Lee
Master
Level 3:
Answers
409
Questions
Helped
104916
Points
1133
It may be a bad inverter but it probably will have to have a new screen.
1 Related Answer
durtopian
Toby Lee
  • 409 Answers
  • Posted on Jul 27, 2009
SOURCE: screem oroblem
You may be able to lighten it up with your keypad if not the screen or video inverter is bad.
How can I disassemble a gateway 7320gz?
go to net search Gateway 7320GZ; 7322GZ; 7325GZ; 7326GZ; 7330GH; 7330G service maintenance manual pdf download and save file open file and follow instructions on diss assembly ,it can take awhile to find the manual though ,that is what i usually do when working on any laptop.
Why wont my Gateway NV53A36u turn on ?
if your charger is ok then it will be a problem with the dc jack (where your charger plugs in to) or your actual motherboard.
2answers
Hi my gateway just lost the light on the
Turn it off. Wait 1 hr. Restart. It could be that the video card is overheated.
I HAVE A GATEWAY 7320GZ.IT HAS ISSUES!!!!!!!!WHEN I TURN IT ON IT START 2 BOOT UP,BUT ABOUT 2 OR 3 SEC LATER THE POWER LIGHT STARTS 2 PLINK AND IT JUST POWERS DOWN ALL THE WAY.THIS IS WITH THE POWER CORD...
Hello, you can reset the battery, battery off, after 45 second push down the power botton for 5 secund and release,then put it back the battery and try turn on ,if don't working,you can try follow this link to change the battery.
Amazon com Gateway 7320gz Laptop Replacement AC Power Adapter Includes...
1helpful
Gateway laptop- screen went dark but is still on.
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
1helpful
I've been trying to find a service manual for a Gateway 7320GZ notebook. Anyone know where I can find one?
remember your model is 7320gz notebook but it your notebook is Gateway® 7000 Series
here the site for your notebook series they all the same unless you added something too it like extra ram etc..
http://support.gateway.com/support/manlib/Notebooks/7000/7000.shtml
good luck
Screem oroblem
try to download it from www.gateway.com
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
