No need to download firmware use the sony code 10812 if you have a comcast remote. Tech support says to use either sony or samsung codes.
Hello Nlunde, in order to get the code you will need to update your FW to make the IR sensor accept most universal remote codes (including cable and satellite remotes). In order to get the firmware please send me an email to [email protected], please make sure to include the model #, serial #, and TW # all located on the back of the TV as well as a contact # so I can give you a call if we need any further information. Once the firmware is updated you will be able to program your remote with no problem.
SOURCE: What Is The Comcast Remote Code For Westinghouse
10885...10889....10890...11282...11577....they work however with my tv only changes the channel when i turn it off...comcast said to go get new remote.
SOURCE: need tv codes to program direct tv remote. \r\nI
Try these codes:070,085,001,126,166,079,120 I hope that helps.
SOURCE: Hi, I got two Westinghouse
DirecTV has an optional remote that is able to learn the command pattern from the original remote. Costs a little bit, but is an alternative. Call up DirecTV, if haven't already, as sometimes they will have new codes that are not published in the manual (receiver) yet.
StepNSet
