SOURCE: Euro-Pro X
Check the hose for something clogging it. It will be past the flattened area (by that I mean further from the steam cleaner). It sounds like something got stuck in the hose, and as the steam cleaner kept sucking on the hose, it caused the hose to flatten.
SOURCE: Euro Pro Irons: Less than a year old stop heating up.
hello,
some time no part of our property go bad but what will need is to service them from there dysfunction
the problem of your iron could be from the element and the wire ,the element is the heat provider while the wire is the power supply from the electric
But the fact is that ,the problem of your iron is disconnection of element from the wire what you need to do fix it to unscrew your iron and trace the wire down to the element and see the disconnection am toking about and fix it back
thank you and thanks for using fixya.
Here
is a tip that will help you with cleaning the sole plate of your
iron...
Cleaning
a Steam Iron Soleplate
heatman101
