Question about Motorola Mobility Moto Q
Moto Q charger problem
Okay, so I just got a moto q, and the charger for some reason doesnt seem like its connecting. I can plug it in the phone over and over and nothing happens. Although - every once in a great while it charges. And I know its not a wire shortage because once it starts charging it doesnt matter how much you move it, it still charges. I just would like it to charge EVERY time I plug it in.... What to do??
  • 2 more comments
  • Zumbafix Aug 18, 2008
    Moto q won't charge properly. It's like it's not making a good connection. When it does charge, it stays charged for at least a day - but very unpredictable. What's up with that? The car charger seems to work better than the house charger. Tried removing the battery and then it wouldn't turn back on easily.
  • onmybirthday Sep 08, 2008
    I also have the same problem. When I plug my phone in to charge it shows the "plug in" icon at the top corner of the screen. The problem is that it only charges when it feels like it (maybe once out of every 10 tries). So I've resorted to charging my phone when it's off. That's the only way I know it's charging for sure. With my Motorola car jack the screen stays lit up the whole time if the phone is on or off while it's plugged in. Again it doesn't charge up while it's on.
  • hurricane9Q Sep 22, 2008
    Yes, I have the Moto-Q as well and I plug it into the wall charger and it won't charge even though the icon on the panel looks like its charging (e.g. it has the exclamation ! next ot the charge icon). This is annoying because I'll plug it in over night and the next morning when I unplug it there is no charge.
    Is there a fix for this? It is not the charger because I have 3 separate chargers that I have tried and the battery is new so I'm wondering if it is a software (OEM) issue. Any informaiton is appreciated.
    Thanks,
  • Terry Wohl Dec 11, 2017
    You probably have some debris inside the charging port that is keeping the plug from going in all the way. Under a strong light and with magnifying glass, I was able to take a sewing needle and carefully loosen the debris and then suck it out with a vacuum cleaner. Everything works fine now.
    Problem Solver:
  • 11 Answers
If you plug the charger into your phone and the battery icon does not change, then it means your physical connection is loose. If the battery connection does change but will not hold charge, then the battery is dead. I have managed 20 Q's in our office. Most of the time we just buy new batteries. Sometimes I fixed the connection by doing the following:
Use a needle nose plier and squueze the mini usb tip on the chargerslightly...very slightly. This will give it a "tighter" fit when you plug it into your phone. Make sure it's unplugged from the wall when you are doing this =).
Posted on Sep 22, 2008
  • jonkimsr
    jonkimsr Jun 30, 2012
    mikev80 thank bud. can't believe that worked.
6ya staff
SOURCE:
Okay. When i plug in my charger to my phone, it will not charge for anything! It may be a possibility that i spilled some yogurt on it also /: but there is nothing wrong with the phone itself.. Like it...
Did spill the yogurt on the phone, or on the charger?
What happend when you plugged in the charger, specifically? Did your phone turn off, if not, were there any changes on the display, did the battery bars blink?
Also, if this is your AC charger for inside your home, do you have a car charger and have you tried it? If your car charger works, or if you are able to borrow someone's charger and IT works, then YOUR charger needs to be replaced. Best Buy, Wal Mart Electronic dept,or Staples, Office Depot, all these retail outlets sell replacement AC and DC ( 12v battery ) chargers. Cellphone chargers are notoriously easy to break, its not unusual to have to replace it during the life of any given phone.
You could try wiggling the connector, and watching the display to see if you have intermittent contact. Most of the ones I've had to replace were like that. They would only work if I pushed in the connector, or held it a certain way. If I just hooked it up and left it, it would not make a connection to the juice. Watch the display closely as your wiggling. You are looking to see if the display light up, or the battery bars to blink. If you can see it connect, even intermittently, you know your phone, and its ability to charge is okay,
Feb 01, 2011 | Cell Phones
My phone is fairly new ( a few months old) and for some reason the charger wont charge when I plug it in. I've tried unplugging it, putting it in different outlets, taking the battery in and out etc but...
i think your baterry is drained already..try to charge your battery in a universal charger, or a clip charger.then continue charging with your original chargermoz-screenshot.png7bf4754.jpeg
Apr 13, 2010 | Motorola Mobility W376 Cell Phone
Viewty lite + charger, nothing else!
Uninstall the LG PC suite and the plug the back in and openmy computer and it'll be in there.
Aug 23, 2009 | LG KU990 Viewty
Unauthorized charger
change your battery and charger. tnx
Jul 28, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Moto is froze?
Easy fix for most things pull out the battery im pretty sure this will work o and if it doesnt take out the battery and then plug in your charger your phone will still operate just wont charge plugging this in and your problem being resolved might just be a short in the battery which mens you need a new one
BestWishes                  -SunShine-
Jul 04, 2009 | Motorola Mobility RAZR V3
Not charging
either have bad battery or the plug in connection is loose or bad.
Oct 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Phone shut off
Plug it into your walloutlet usb charger rather then the one connected to your pc. once your battery is so low it wont even have enough juice to show the charge battery screen if your chargeing through the low voltage pc active sync cable.
Feb 11, 2008 | Motorola Mobility Moto Q
Phone simply wont charge
You have to use right Charger Model :PSM5049 A
Input 100/240V ~50/60 Hz .0.4A (Amper) !!!!!!!
Output 4.4V --1.5 A
The one you using probably is for Blure Tooth wich is weaker:
Model PSM 5037B
Input 100/240V ~50/60Hz 0.1A Amper
Output 5.9V 375mA
Aug 19, 2007 | Motorola Mobility A1000
Open Questions:
boot_c_03.08.00r_mpap Paul Sager from FixYa has posted a solution for this problem previousley (as below). I have tried the Motorola and Verizon sites (tried the store as well) and the software is not available to flash the phone. Do you know of a site that would still have it available? Or can this question be sent to Paul to further comment on it? All I want to do is recover the phone numbers, notes and calandar from the phone via Activesync or Windows. Paul Sager 2335 Solutions July 14, 2010 I can help you with your Motorola Moto Q. What has happened is that the firmware of your phone has become corrupted. When this happens your phone will no longer finish its boot sequence. This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware. The good news is that if you take your phone into your carrier's store, they can reflash it for you right there (if they have a competent tech handy.) If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times. My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone. I hope that helps.
Oct 09, 2012 | Motorola Mobility Moto Q
See all Motorola Mobility Moto Q Questions
Motorola Mobility Moto Q Logo
1,029 people viewed this question
Top Motorola Mobility Computers & Internet Experts
 Paul Flint
Paul Flint
Level 1 Expert
Tom Chichester
JessicaChane2345
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
