Master
- Posted on May 09, 2011
Re: Motor has been checked ok when is turned on it...
You must see with a volt meter, if you are getting arequired power. It can be weak motor or defective motor controller issue. The interiormotor links are loose or the belt is dried up use some basic lubing by grease.If the problem still exists then you may need to replace motor controller ormotor.
thank you i guess it has to be motor or controller
