New Balance 1400 Treadmill Logo
Posted on May 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My New Balance 1400 treadmill recently stopped working. There is power going to the motor. The lights are on but there is no power to the display. nothing lights up and none of eh controls work. The treadmill is about 2 years old and not used all that much. Any ideas.
John Mazmanian
Level 3:
President:
  • New Balance Master 832 Answers
  • Posted on May 09, 2011
John Mazmanian
New Balance Master
Level 3:
President:
Answers
832
Questions
0
Helped
628332
Points
2056
It sound like either the wire harness that goes to upper console is bad or the Motor Control Board that has the 5v or 12v is missing. Here is the bad news New Balance is out of the Treadmill business and do not carry these items anymore. Their might be one other thing you might try is that if this unit was not maintain as owner's manual suggests, then the fuse may have open up. You must open the motor shroud locate motor control board find the fuse, if you have a multi meter check continuity of the fuse if open replace it with the same value ( maybe 15amps). Plug unit in if the display returns then proceed to do the prescribe maintenance in owner's hopefully that the belt and deck was not damaged when it went dead.
Good Luck!!
Max
I have a New Balance 1400. How do you do a hard reset on it?
In almost all treadmill error 1 denotes the speed sensor error.
In you case I suspect there is some variation in the alignment of the speed sensor. May it moved away from the magnet Which is fixed on the rotating wheel. Try to make it closer as much as it can, be sure not to keep a small distance .hope it will solve the problem.
If you wish to get some more details about treadmill repair and service then check the following link.
http://electro-medical.blogspot.com/
I have an older NB 1400 Treadmill (7 years old)
Motor controls for New Balance can be found by doing a Google search on Treadmill Analyzer and look for the MCB List page of repairs offered :-)
My Reebok v6.80 treadmill turns and lights up but won't go.
1) LUBE the deck belt,you have a WORN deck belt, this happen because you didnot lube according with the schedule maintenance
29 LUBE the rollers bearing too
3) Test the drive belt motor, for worn or crack, or adjust if is possible
4) Test the input voltage motor, if there are the motor need repair
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
My tread mill stop working i have green light in the electonic board 5 small light not on
You need a new controller board. You can check your manual for how to order replacement parts. It will not be available on the New Balance website. It will actually be from an off-brand treadmill manufacturer that made the treadmill for New Balance.
Have a new balance 1400 treadmill. when i power it on the screen goes blue and it will not doing anything.
Does the screen turn on (blue) and then go black or does it stay blue? Mine has a similar problem where when the main power switch is flipped, it lights up, shows the initialization screen, then goes dark. Pressing any button on the console does nothing. I opened the console up and suspect one programmable microcontroller is bad. I'm going to see if I can get that part from FitnessQuest instead of replacing the whole board.
2helpful
I can not get the treadmill to power on.
I have the same problem and have isolated it to the main console board. When you flip the main power switch, does the console display light up briefly and then go dark?
2helpful
I have a 1400 that when it has been running for 20 or 30 minutes goes to Power Failure and generally throw me against the rail to an abrupt stop. I do believe it is home electrical as I run a 20 amp...
This generally means that lubrication is needed to be applied between the belt and belt. You may purchase these kits thru www.jadfitness.com the products name is Lube and Walk follow the instructions that come with it to apply the lubrication.
1helpful
ERR 1 on NEW BALANCE 1800 Treadmill
It is on the circuit board, It is white or gray with silver on the ends and it will be about an inch long and tubular. eric
Life Fitness T3 treadmill won't turn on. Power from outlet is fine. 4 red lights are on by motor under front floor panel. Tried resetting, per owner's manual (pressing Stop and Down Speed), but nothing...
Could be. If you had to take it apart, I would definately check the wire harness connection. Also if there are bolts that were removed, check to make sure none of those pinched the harness when reassembling.
Top New Balance Exercise & Fitness Experts
ZJ Limited
ZJ Limited
john h
Are you a New Balance Exercise and Fitnes Expert? Answer questions, earn points and help others
