If you are trying to
connect through a modem/router you it should have come with a disk then
you might have to connect
the usb lead to your modem to get a connection then
click start control
panel,administrive tools,computer management,device manager scroll to network
adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP
internet service provider
or the motherboard disc
hope this helps or you could download
Realtek RTL8168/8111 PCI-E
Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html Realtek RTL8168/8111 PCI-E Gigabit Ethernet
NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed
IEEE 802.3 compliant Media Access Controller (MAC) with a triple-speed Ethernet
transceiver, PCI Express bus controller, and embedded memory. With state-of-the-art
DSP technology and mixed-mode signal technology, it offers high-speed
transmission over CAT 5 UTP cable or CAT 3 UTP (10Mbps only) cable. Functions
such as Crossover Detection & Auto-Correction, polarity correction,
adaptive equalization, cross-talk cancellation, echo cancellation, timing
recovery, and error correction are implemented to provide robust transmission
and reception capability at high speeds.
hope this helps
if the first one is wronghttp://download.cnet.com/%7Bvalue=http:/...
? Intel(R) PRO/100B PCI Adapter (TX)
? Intel(R) PRO/100B PCI Adapter (T4)
? Intel(R) PRO/10+ PCI Adapter
? Intel(R) PRO/100 WfM PCI Adapter
? Intel 82557-based Integrated Ethernet PCI (10/100)
? 82557-based Integrated Ethernet with Wake on LAN
? Intel 82558-based Integrated Ethernet
? Intel 82558-based Integrated Ethernet with Wake on LAN
? Intel(R) PRO/100+ PCI Adapter
? Intel(R) PRO/100+ Management Adapter
? Intel(R) PRO/100+ Alert On LAN II* Adapter
? Intel(R) PRO/100+ Management Adapter with Alert On LAN*
? Intel(R) PRO/100+ Server Adapter
? Intel(R) PRO/100+ Dual Port Adapter
? Intel(R) 82559 Fast Ethernet LAN on Motherboard
? Intel(R) 82559 Fast Ethernet LOM with Basic Alert on LAN*
? Intel(R) 82559 Fast Ethernet LOM with Alert on LAN II*
? Intel(R) PRO/100 CardBus II
? Intel(R) PRO/100 LAN+Modem56 CardBus II
hope this hepls
