First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
If you have a light on ( standby light ), then I would say power supply fault, tv could be shut down because of faulty capacitors in power supply. if you dont have any lights at all , check fuse in plug, ( there will almost certainly be a fuse in the tv) but, that is for a tv guy to fix. pete
Hi: This could be caused by a surge that may of damaged the Power supply unit. Replacing the power supply board is a good option at this point, you did not mention if you are able to watch the set, but if so and this is happening when you turn off the set the the system control board which controls the power on/off of the power supply may also of been affected.
