Open the right side door. there at the bottom is a long plastic bottle full of waste toner. If you have no spare bottle then carefully (dont create dust) empty toner into a bin liner. Now tap the bottle on the table to allow any toner on the sides to fall back to the bottom. now refit and all should be well.
SOURCE: error 82 replace waste toner
THE WASTE TONER IS THE PLACE WHERE THE CARTIDGE IS PARKED WHEN NOT IN USE. IT IS USUALLY IN THE RIGHT SIDE CORNER.
SOURCE: Oki c9600 printer - waste toner box
Did you first try and dump the waste toner out of the waste toner bottle? If so it never completly gets empty. It is compacted at the end where the opening is. When the mach fires up the gears that drive the waste bottle break.
Set toner container. The toner container is not set properly. Set the toner container properly. See page 5-5 of the operation guide.
Replace Waste Toner Box The waste toner box is full. Replace the waste toner box with a new one. See page 5-5 of the operation guide.
