You should be talking to Electrolux...
Hi. - Looks like it:
Electrolux Vacuum Cleaner Hose Assembly Z4 Series
SOURCE: Hoover z400 clogged
There should be a bottom plate covering the brush roll that you can remove, if you can't dig out the what is in there, try using your hose and suck it out from the bottom, maybe you will be able to get it out.
SOURCE: Water leaking out bottom with hose attached
The water hose plugs into the solution valve-pressure on the side of the noozle(bottom). There may be a water line that has come loose there, you will have to take the top off to get to it.
SOURCE: model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Model 116 hose clog?
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: attach upholstery hose
Go to www.Hoover.com. Click on Carpet Cleaners. Click on Steam Vac All Terrain. Click on Learn more. Then click on Download the manual in pdf. The manual explains all.
SOURCE: electrolux canister special edition problem
If this canister has a "bag full" light and auto shutoff, there is an internal diaphragm switch controlled by a dial on top of the vac. Set the dial for medium setting. Install a fresh bag and test again.
There is a pinhole in the throat of the vac which allows air to flow through a tube to the diaphragm. Check to see that it is not blocked with a grain of sand. There is a second pin hole in the corner of the bag chamber check there as well for blockage. If this vac is less than 20 years old the control valve for the diaphragm often cracks and needs to be replaced. You would access it by peeling ( like a banana) the soft rubber bumpers off the side of the vac and sliding the locking keys underneath the bumper out the front end of the vac when the bag door is open.Then gently popping the housing apart from FRONT to back. DO NOT try to pry the back housing off. Caution, this is normally performed on a cradle in a repair shop designed to hold all the components in place
